LED mod inside
Old May 11, 2008 | 04:08 PM
VetteFTW's Avatar
VetteFTW
Default LED mod inside
Which one of these is positive and which is negative, the one that is longer by the look in the bulb looks like it should be negative, but people say that longer is "always" positive. Anyone able to shed light? I got this from OZNIUM.
Old May 11, 2008 | 04:18 PM
minitech's Avatar
minitech
It is indeed a fact, long one always positive. And easy to check out. Use a resistor and a 9 volt battery. One way will not light, the other will as it is a diode......
Old May 11, 2008 | 04:38 PM
VetteFTW's Avatar
VetteFTW
Oh ok, because the one above is red, and the blue one is the opposite of that, the one that should be positive, is longer. I just thought its weird that they're different.
To LED mod inside
