column lock recall
Old May 13, 2008 | 06:28 AM
toolguy66's Avatar
toolguy66
Default column lock recall
I have a question about column lock recall/fix.
I'm about to go see a car to buy and when I asked if the lock issue was dealt with he said the error code came up so he took it to the dealer to see what was wrong and they told him that it was already fixed by the previous owner, and that if he wanted to get rid of the code he would have to pay $700 for a new harness.
Does this sound right to anyone?
Thanks, Mark
Old May 13, 2008 | 06:36 AM
gdaddee's Avatar
gdaddee
I believe that what I say will be echoed by almost everyone that respones. The only way to solve this is to install the column lock bypass (clb) device. About $50.00. Stay away from the dealership.
Old May 13, 2008 | 06:43 AM
Best $50 you will spend on the car.
Old May 13, 2008 | 11:31 AM
GRUNIE's Avatar
GRUNIE
Get the CLB from Corvettes of Houston. You can't go wrong. Around $50 bucks. Pretty easy install.
Old May 13, 2008 | 11:38 AM
vermjpv's Avatar
vermjpv
Now a CTS-V Owner
CI 5-6-7 & 9 Veteran
St. Jude Donor '05-'06-'07-'08
Old May 13, 2008 | 11:47 AM
MorpheusGPR's Avatar
MorpheusGPR
I just had the recall done.
Old May 13, 2008 | 11:48 AM
Independent1's Avatar
Independent1
St. Jude Donor '08
There have been so many posts on this subject I don't know where to begin!
Why don't you start here.
http://forums.corvetteforum.com/show....php?t=1015483
Have fun reading
Probably more than you ever wanted to know.
Good luck and hope you get it fixed.
Old May 13, 2008 | 09:04 PM
toolguy66's Avatar
toolguy66
Thanks so much to everyone, that helps alot
To column lock recall
