c1226
Old May 13, 2008 | 07:28 PM
c213854's Avatar
c213854
Default c1226
i did a search online and found out that it is most likely a wire im just not sure where the wire is. can anyone tell me the procass of checking it also can it be the cause of my traction and abs lights coming on.
thankyou
D.J.
Old May 13, 2008 | 09:39 PM
Bill Dearborn's Avatar
Bill Dearborn
You can check the WSS by pulling the right front wheel. The connector is on a clip behind the brake rotor. By pulling the connector you can check the sensor. You should also check the connector pins for corrosion and also check the connector pins at the EBCM for corrosion.
Bill
Old May 15, 2008 | 09:28 PM
c213854's Avatar
c213854
thanks for the reply looks like i have something to do tommorow
To c1226
