no go
Old May 13, 2008 | 08:00 PM
redrager's Avatar
redrager
Default no go
I have a 98 automatic;I replaced the shifter assembly;the entire piece;when I was done the car will not start;all I get is a click when I try to start it;i know the battery; starter are good.what gives?
Old May 13, 2008 | 08:44 PM
troy144's Avatar
troy144
That sucks. Someone else can help TTT
Old May 13, 2008 | 08:46 PM
rob-cyn's Avatar
rob-cyn
Sounds like the shifter is not set all the way in park. Did you try moving it to neutral and try to start it ? Try moving the shifter to other gears and wiggle the shifter as you turn the key, just make sure you have the parking brake on so you dont end up in the kitchen. I had a similar problem on a Camaro and needed to adjust the shifter a little.
Old May 13, 2008 | 08:55 PM
00 Rooster's Avatar
00 Rooster
St. Jude Donor '08
I know, your car wants a manual transmission
Sorry, I'm no help but at least this is a bump for you. Good luck with your fix
To no go
