Tire Valve Stems
Old May 13, 2008 | 08:11 PM
1FINE99's Avatar
1FINE99
Cruise-In IV Veteran
Cruise-In V Veteran
Default Tire Valve Stems
Can you put in regular valve stems if you take out your TPS'S ? I'm thinking about trying to replace the batteries in my TPS'S and I would have to get air back in the tires until they were done.
Old May 13, 2008 | 08:27 PM
MR.WaynesWorld's Avatar
MR.WaynesWorld
From: The real question is; When you turn your car on, does it return the favor..
Cruise-In VIII & IX Veteran
St. Jude Donor '07-'08
Yepper....
Old May 13, 2008 | 08:31 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
pm Corvette Don,
He is a TPS guru around here!
Old May 13, 2008 | 09:37 PM
dobewillie's Avatar
dobewillie
should not be a problem
Old May 13, 2008 | 09:41 PM
MagneticRed1977's Avatar
MagneticRed1977
Is not a problem my Ruffs are that way until I get the sensors in.
To Tire Valve Stems
