Jacking / Hockey PUCKS
Old May 15, 2008 | 06:17 PM
pec98's Avatar
pec98
Default Jacking / Hockey PUCKS
Thanks Guys , for the info on how to make Jacking pucks from hockey pucks. I bought used pucks from Play it Again Sports @ 59cents each. And 4 , 3/8 eye bolts from Menards . Drilled a 1/4 inch hole , screwed them in , and ground off the exess from the other side. Under 5 bucks and they work Great.
Old May 15, 2008 | 06:20 PM
csexton's Avatar
csexton
I've been using mine for years
Chuck
Old May 15, 2008 | 07:05 PM
c3spdrcr20's Avatar
c3spdrcr20
Excellent idea on the used pucks! I'm cheap and proud. Didn't buy a vet by throwing all my pennies away!
Old May 15, 2008 | 10:46 PM
pec98's Avatar
pec98
Default lifting pucks
One other thing...... the pucks sold by some Corvette vendors are very thin. If you jack is like mine it has a concave lifting bowel on the end of the jack and these pucks are too thin. Thats not the case with the hockey pucks they are just the right thickness.
Old May 15, 2008 | 10:51 PM
VLVETTE's Avatar
VLVETTE
I did mine double thick. JB welded
Old May 15, 2008 | 10:55 PM
itzza427's Avatar
itzza427
Is that a reflection or are you using two pucks?? I want to do this,,better than using a chunk of 2X4 !!!
Old May 16, 2008 | 07:20 AM
RonJ's Avatar
RonJ
Can't see dropping $60+ at a BMW dealership when pucks do the job 100%.
Some folks want glamour over function I guess ... <G>
RonJ ...
Old May 16, 2008 | 11:33 AM
Red3644's Avatar
Red3644
Default Hockey puck?
Where the hell do you get a hockey puck in TEXAS. "Hockey" doesn't
even sound good. I'd still like to get some if I can find someone
around here who knows what they are.
Michael...sunny and 85 at the Alamo.
Old May 16, 2008 | 02:30 PM
robsc501's Avatar
robsc501
Hi There,
Usually at a sporting goods store or ask Jim Bowie.
Old May 16, 2008 | 02:42 PM
Red3644's Avatar
Red3644
I'll try but the stores around here don't cater to "winter sports". I last saw snow here in '84. Thanks.
Old May 16, 2008 | 03:27 PM
robsc501's Avatar
robsc501
Default Jacking/ Hockey Pucks
Hi Red 3644,
If you can't find any pucks in a sporting goods store make your own.I,am measuring them as I type this. The eye bolts measure 1 & 1/16" wide( Lowes p/n H#35226 sold in a clear plastic box of 6) Used a 1/4" drill bit. The height of the installed eye bolt is 1 1/4".That height allows you to insert & turn & lock the puck into place. The puck is 1" thick & 3" wide. I would use a 2x4 piece of scrap wood which will add a 1/2" extra thickness.More thickness might be required if your floor jack base is concave instead of flat.Tip: Solid oak is stronger & lasts longer.
When I was at Lackland afb in sep. of 65 I didn't see Jim Bowie either because we all slept on top on the covers on our bunks, thanks to the drill instructor lol Any way I hope this helps you out.
robsc501
Old May 16, 2008 | 08:46 PM
trickflow's Avatar
trickflow
I found them in Florida, new for 97 cents so I made the double set up
To Jacking / Hockey PUCKS
