New Water Pump ????
Old May 16, 2008 | 05:39 PM
98blackonblack's Avatar
98blackonblack
Default New Water Pump ????
Alright well my A/C compressor is puking oil out of the bottom, so I've got a new compressor and collecting the rest of the parts to do the job, and since you have to take the water pump off to change the compressor out, I figured with 98,000 miles I should go ahead and change the water pump out since I'll have it off anyways. So my question....I'm on a budget, and the A/C is already breaking it, would autozones "New" Duralast pump, gaskets, and thermastat, be ok or should I cough the extra $85 up and order one from gmpartshouse with the thermastat already on it?
Old May 16, 2008 | 06:35 PM
CaptKirk's Avatar
CaptKirk
I had my OEM water pump seize at about 45K miles. I opped for the AutoZone water pump and have about 10K miles on it now. I installed the new one myself and it really wasn't any big deal. So far, no problems - knock on wood.
P.S. I've had my A/C compressor leak oil from time to time after using the A/C. It looks like the the oil was leaking from the O rings at the connnections. Because it was happening intermittently, my A/C guy told me not to worry too much about and to bring it in when I can and he would change the O rings. I haven't been using the A/C too much and it hasn't leaked recently. Is your compressor leaking from the O rings too?
Old May 16, 2008 | 06:48 PM
corvettetomct's Avatar
corvettetomct
98 ... if you are going to keep the car,get the good one.... if your going to sell it get the cheap one.... and maybe the cheap will last... tom
Old May 16, 2008 | 08:27 PM
98blackonblack
I need to craw under the car and check, but the underside of the compressor is drinched, and the other day i backed out of the garage there was a coffee can size puddle, i dont think a leaky o-ring would cause this much leakage.
Old May 16, 2008 | 09:09 PM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
I wouldn't have a problem with the Duralast water pump from Auto Zone.
I believe it's comes with a lifetime replacement warranty,which you don't get with a GM replacement part.
Old May 16, 2008 | 09:53 PM
Ron C!'s Avatar
Ron C!
PM sent.
Old May 19, 2008 | 04:42 PM
98blackonblack
Anyone have any experience with NAPA brand water pump, found a guy that had bought a new napa pump, but never used it, $50, sounds like an awesome deal to me, but I don't want to skimp on quality if its a crappy pump then I dont have a problem spending the $240 for a gm...just curious if anyone knows anything about them, or who makes them
Old May 19, 2008 | 10:51 PM
Good point.
Old May 20, 2008 | 06:14 AM
HMannini's Avatar
HMannini
Cruise-In X Veteran
St. Jude Donor '09
My water pump went belly up at 41,000 miles, I had the option of an AC Delco or Napa pump, the Delco was $300 more than the Napa and the Napa had a lifetime guarantee. No problem at all with the Napa pump.......
To New Water Pump ????
