[Z06] Low Oil Level message??
Old Dec 18, 2001 | 09:13 AM
01ZoomO6's Avatar
01ZoomO6
3rd Gear
Default Low Oil Level message??
If this light comes on, does it indicate 1 quart low or is is it more than that?
Old Dec 18, 2001 | 10:36 AM
jerryv's Avatar
jerryv
Default Re: Low Oil Level message?? (01ZoomO6)
Well, I don't know .. but it certainly means 'check the dipstick and prepare to add oil'
Old Dec 18, 2001 | 11:15 AM
ZO6LS6's Avatar
ZO6LS6
01, most folks indicate 1 full quart low.......then, re-check...........
Old Dec 18, 2001 | 06:26 PM
BradJ's Avatar
BradJ
Default Re: Low Oil Level message?? (ZO6LS6)
When the message came on in my '01, it held almost two quarts!
Old Dec 18, 2001 | 06:49 PM
MikeFleischer's Avatar
MikeFleischer
I've had to add anywhere from 1 1/2 to two quarts...
01 Z06.
Old Dec 18, 2001 | 09:47 PM
ZO6LS6's Avatar
ZO6LS6
Default Re: Low Oil Level message?? (MikeFleischer)
Did you try and check the levels after the car sat OVERNIGHT, or right away??.
Because ot DO make a difference..........and when the ADD light came on, where was the LEVEL on your stick???
[Modified by ZO6LS6, 1:48 AM 12/19/2001]
Old Dec 20, 2001 | 06:09 PM
MikeFleischer
Umm,
I added oil right away, the level was at the bottom of the dip stick (just under the first indent). I added until the oil came to the fill line.
Is this not the right way to go? I would think it needs to be checked hot and if you fill it hot, it shouldn't hurt anything too much?
Old Dec 21, 2001 | 11:08 AM
ZO6LS6's Avatar
ZO6LS6
Mike, how much did you add?????
Old Dec 21, 2001 | 11:58 AM
Zee Freak's Avatar
Zee Freak
St. Jude Donor '03-'05-'06
I had the same problem. Mine took two full quarts too fill it to half way between the dots. Then the light didnt go out till the next day.
To Low Oil Level message??
