Suspension Question
Old May 18, 2008 | 08:13 AM
disney04's Avatar
disney04
Default Suspension Question
I have a 99 Coupe with 17 K. Does a C5 have shocks and struts. When should I replace them? Also, How many miles on average do the OEM runflats get before needing to be replaced.
Old May 18, 2008 | 09:03 AM
vettman96's Avatar
vettman96
C5 suspension is by transverse composite leaf springs frt and rear with gas charged shocks (active suspension uses electro-magnetic shocks I believe). No Struts. With 17k on the clock you are a long way from having to address anything unless you are modding the chassis.
Old May 19, 2008 | 11:54 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
Unless one is leaking or you want some better shocks you are just fine
To Suspension Question
