Backup LED lights
Old May 18, 2008 | 05:11 PM
eec8059's Avatar
eec8059
Default Backup LED lights
I bought these for my backup lights but I'm having an issue.
The LEDs are ON at all times when the car is running.
When I put it in reverse, they bright ON stronger.
Bottom line, these bulbs are always ON. weird
What's up with this? Any ideas?
Old May 18, 2008 | 06:47 PM
jdmvette's Avatar
jdmvette
Night Owl for life
what is the model number?
Old May 18, 2008 | 09:37 PM
fireman591's Avatar
fireman591
LED bulbs will light with very little current.
I would put a volt and amp meter on the pigtail to see if you are getting alot of power to them when they should be off.
If it is very minimal leak, you can add a small inline resistor to soak up any stray power going to the lights till the reverse lights are suppose to come on.
Post this in the tech section also.They might be able to help even more.
Keep us posted
fireman591
Old May 18, 2008 | 10:05 PM
jdmvette's Avatar
jdmvette
Night Owl for life
my LED backup lights have never had a problem.
Old May 19, 2008 | 12:35 AM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Perhaps you have the wrong model bulbs. I believe you have the 1157 style bulbs which are the LED equivalent of dual filament turn signal/running light bulbs. You need the 1057 version.
FYI: LED bulbs throw out significantly less light than an incandescent bulb. Great for effects but poor in performance.
Old May 19, 2008 | 12:38 AM
BOTYNV1's Avatar
BOTYNV1
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
easy fix
Old May 19, 2008 | 05:44 AM
fireman591's Avatar
fireman591
I put halpgen ones in mine.
They are smaller and are 2 1/2 times brighter than stock.
Most motorcycle shops sell them.
Old May 19, 2008 | 07:29 PM
eec8059's Avatar
eec8059
THe bulbs are 1157 SMT Tower LED bulbs from autolumination.com.
I don't see any 1057 option on this website. ANybody have a link or
some other website?
Will an 100 ohm equalizer do the trick? Thanks.
Old May 19, 2008 | 08:19 PM
jdmvette's Avatar
jdmvette
Night Owl for life
it might be because they're the "SMT" version. theradioflyer posted in here that he had problems with SMT before. http://forums.corvetteforum.com/show...&highlight=smt
i use the light tower II 20 LED bulbs for my backup lights with no problems.
Old May 19, 2008 | 08:53 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
My problem was when they SMT tower bulbs were used in the DRL/Turn signals. This probably has somthing to do with the DRL turn/signal setup on the corvette where the DRLS are on full until the parking lights are on and the flasher adjust to flash either more or less bright.
jdmvette: did your owl decided to look the other direction today?
Old May 19, 2008 | 09:09 PM
11yellowgscpe's Avatar
11yellowgscpe
I use the 1157 from Forum Vendor Corvette Enhancements with no problems
Old May 19, 2008 | 09:58 PM
10U 99's Avatar
10U 99
St. Jude Donor '08-'09
this is what I'm using for back up lamps, very bright
Old May 19, 2008 | 11:24 PM
jdmvette's Avatar
jdmvette
Night Owl for life
Old May 20, 2008 | 12:22 AM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
are those 3watt?
Old May 20, 2008 | 01:08 AM
eec8059's Avatar
eec8059
Thanks for the info "jdmvette".
So, anything that isn't SMT is fair game then.
I'll try the tower 2s and let you guys know of the outcome.
Old May 20, 2008 | 03:03 PM
10U 99's Avatar
10U 99
are those 3watt?
5 watt, Eagle Eye 5
Old May 20, 2008 | 03:20 PM
RBChallenger's Avatar
RBChallenger
How is the actual light output on these compared to stock?
RBChallenger
Happen to have a part number?
Old May 20, 2008 | 08:02 PM
jdmvette's Avatar
jdmvette
Night Owl for life
stock halogen will always be brighter than LED. the LED look much cooler in the diamond cut housing, though and draw less current.
To Backup LED lights
