Lowering question (slightly technical)
My question is: do the bolts directly control ride height, and is the adjustment linear? In other words, can I use the thread pitch and number of turns of the bolt to gauge exactly how much I'm dropping?
Or, is it a function of the spring? In other words, if I drop the car, will the spring be loaded more and therefore give a non-linear drop?
Or, does the composite leaf spring give a fixed spring rate, and lowering will give a linear drop based on the spring and not the thread pitch?
I want to be able to to measure my drop (even if indirectly) without having to put the tires back on, drive around, let it settle, measure and repeat.
Hopefully my question is clearer than mud.
No, it is not directly linear in your terms.
Differences in the shocks, even between the same type, and the springs cause a variation in the total amount the car will lower.
For instance, I find that standard c5's (non Z06) will lower slightly more than Z06's will.
The amount you lower if you go all the way from the factory setting to as low as you can go on the stock adjusters is just less than an inch, and that is consistent across all of the cars I have lowered.
You do not have to remove the wheels to lower the car - just get it in the air.
Many use the measure of the center of the outer wheel wells to the ground both before and after the bolts are turned.
In my experience, once the tires have seated themselves on the ground, the car does not lower itself in any measurable way by "settling" - but that is just my experience after having lowered as many C5's as I could talk the owners into doing so.....
best regards -
mqqn
Thoughts, anyone?
