Trouble
Old May 20, 2008 | 04:27 AM
99C5x's Avatar
99C5x
Default Trouble
Alright, well maybe someone can help me out. This is what happened to me here about 30-45minutes ago. I was driving and then I went from full rpm'd 4th gear and i think i hit 3rd gear instead of 5th =( I think the problem is grave. My engine did turn off as I veered off to the service road and then I stopped. I cranked the engine and it seemed to be fine except with a much much higher lopping than usual. I proceeding to go to my destination and now I am back safely home. The check engine light is of course blinking. The car still pulls from 3 to 6K rpms flawlessly. I recently (5k miles ago) had a Z-Grip installed. It definitely sounds like an engine problem. I have chrome moly 7.4 pushrods, and everything else is stock on my 00. If anyone has any possibilities of what could be the problem i'd appreciate the insight. As of now I am evaluating it as a valve problem. The car like said is a stock 00 with just at 90K. =( I'm sorry for my driving skills, I am only trying to get better
Cheers,
Old May 20, 2008 | 04:42 AM
Cajun99's Avatar
Cajun99
Your explanation is kinda vague as to what the car is doing.
Pull the codes and see if she'll talk to you
http://www.stengel.net/diccodes.htm
Old May 20, 2008 | 06:53 AM
Porxter's Avatar
Porxter
Might have bent some pushrods if it over-revved to much...
Old May 20, 2008 | 08:15 AM
99C5x's Avatar
99C5x
I was pushing the car, at the limits and instead of hitting 5th like I should i hit 4rd as an amateur.
Old May 20, 2008 | 08:28 AM
RUNNINGMAN 1's Avatar
RUNNINGMAN 1
After realizing there was a problem why oh why would you push the car to 6 grand
Old May 20, 2008 | 08:53 AM
J S Machine's Avatar
J S Machine
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17
St. Jude Knife Maker
Is it possible to float the valves on these engines? Just a suggestion. hopefully not the case, but an idea as to what it could be.
Old May 20, 2008 | 09:16 AM
VinnyT's Avatar
VinnyT
I agree. That could do even MORE damage. A valve or pushrod could be bent. Do not run it hard until you or someone looks at it!!
Old May 20, 2008 | 10:18 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Take your pushrods out and roll them on a flat surface. You will see if any are bent. If none are, do a compression test. You could have collapsed a lifter, weakened or broken a valve spring or bent a valve. This usually causes some sort of valvetrain damage. I would expect you to hear ticking though. Replace your spark plugs and inspect the old ones.
To Trouble
