Loose Passenger Side Mirror
Old May 20, 2008 | 02:49 PM
Black_6-Speed's Avatar
Black_6-Speed
Default Loose Passenger Side Mirror
My passenger side mirror has come loose, and I have done some research. It is looking like I will have to take the entire door apart to fix this one myself. Can someone please tell me I'm wrong and that there is a much easier/cleaner fix for this problem? Or, does anyone know what it might cost to have the stealership or trustworthy body shop do it? Thanks in advance!
Old May 20, 2008 | 02:58 PM
HMannini's Avatar
HMannini
Cruise-In X Veteran
St. Jude Donor '09
What's probably happened is your retaining spring has popped, a common problem with our cars. You can either put a big gob of glue on it which is usually a temporary fix, buy a new mirror, which is a rather expensive fix because they cost $200+ and you will have to have it painted, or you can remove the mirror and send it to this man who will fix it for $75 with a lifetime guarantee. http://capitalcitycorvette.homestead...s/clubnews.htm Click on C5 Mirror Repair.
I had him fix my passenger mirror and am going to send him my drivers mirror soon. I wish I had known about him a few months ago, it would have saved me time and $...............Good Luck.
Old May 20, 2008 | 04:00 PM
c5streak's Avatar
c5streak
Old May 20, 2008 | 06:46 PM
Autoworker's Avatar
Autoworker
I bought a new mirror and had it painted when I had some bodywork done. I used JB Weld on the old mirror and it held up great until the new mirror was on.
Old May 20, 2008 | 08:03 PM
dobewillie's Avatar
dobewillie
very good info thanks
Old May 21, 2008 | 07:20 AM
Black_6-Speed
Thanks for the replies!
Old May 21, 2008 | 07:33 AM
Black_6-Speed
Does this mean you JB welded the clip on the stem, or can you use JB Weld on plastic?
To Loose Passenger Side Mirror
