New shocks
Old May 22, 2008 | 07:40 AM
EdsC6Z06's Avatar
EdsC6Z06
St. Jude Donor '05-'06-'08-'10
I went C5 Z sway bars with C6 Z shocks. Great ride and handling. Call Gene. Fairly easy sway to do.
Old May 22, 2008 | 08:00 AM
9secondflat's Avatar
9secondflat
just call gene, tell him you own a c5 and want the z06 shocks/bars. he knows what to send.
Originally Posted by vettegator005
so what would be better c6 z06 shocks or bilstein? and does the c6 z06 sway bar fit on the c5 or do i get the c5 z06 sway bar?
Old May 22, 2008 | 11:13 AM
slvr bulit's Avatar
slvr bulit
I ordered my C6 zo6 shocks and c6z51 sway bars from Gene. Don't forget to order the endlinks for the sways as well. I am in stalling them tomorrow. Can't believe how much beefer the shocks and sways look next to my stock ones. I have a 98 coupe with the base suspension now.
Old May 22, 2008 | 12:20 PM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
Originally Posted by rws.1
Many are opting for the C6 Z06 shocks...
Gene at www.gmparthouse.com can set you up for around $250 ( last year)
they are a direct bolt in replacement.
Wonderful ride and heavy duty stability. More reasonable too.
Can't use the word cheaper here.
Only diff. I am told, Billsteins can be rebuilt
Old May 22, 2008 | 12:29 PM
2003z06vette's Avatar
2003z06vette
On the Lingenfelter site they say the Bilsteins are original equipment on the ZR-1. I imagine they are better than the C6 shocks if that's what Chevy is using.
Old May 22, 2008 | 02:11 PM
ScottJ97's Avatar
ScottJ97
I thought the new ZR1 had the magnetic ride system? I remember reading about its special "launch mode" where it detects a hard launch and sets max rebound and min jounce (or is it vice versa).
Old May 22, 2008 | 03:35 PM
2003z06vette
I dunno? I've been looking into getting these shocks and just came across it on Lingenfelter. Not sure if it's true:
http://www.lingenfelter.com/store/be5-2975.html
Old May 22, 2008 | 10:32 PM
lionelhutz's Avatar
lionelhutz
This is a good update and about the cheapest way to do both. I think the C6Z06 shocks work well, even on a lowered car.
It's hard to determine stiffness/ride. Everyone has a different opinion.
Peter
Old May 22, 2008 | 10:44 PM
spicytuna's Avatar
spicytuna
I just installed a set of C6 Z51 sway bars last weekend. Got a wicked deal from a local seller who just upgraded his C6 with a set of Pfadt's at 7000 miles.
A huge difference!
Here's one pic I took of the end-links. As you can see, the 97-00's use a thinner end link vs the 01+ which use metal links.
Old May 23, 2008 | 03:35 PM
UWEBABY's Avatar
UWEBABY
St. Jude Donor '06-'07-'08-'09
I WAS INITIALLY TOLD THE C6 SWAYS WOULDNT FIT. THEN SOMEONE ELSE PUT THEM ON AND THEY WORKED.
RE THE SHOCKS, IVE NEVER HAD BILSTEINS SO I CANT COMMENT. THE GM SHOCKS HAVE BEEN AWESOME.
Old May 23, 2008 | 04:17 PM
Sully C5's Avatar
Sully C5
Cruise-In II Veteran
Since this thread has expanded to include stabilizer bars, I thought I would post a little more info, plus the sequence of the shock & stabilizer mods that we made:
Base Suspension: 23 mm-front / 19.1 mm-rear
Z51 (97-99): 25.4 mm-front / 21.7 mm-rear
Z51 (00-04): 28.6 mm-front / 23.6 mm-rear
Z06: 30.0 mm-front / 23.6 mm-rear
Hotchkis: 31.75 mm-front / 25.4 mm-rear
Addco: 32 mm-front / 25.4 mm-rear
Addco: 35 mm-front / 25.4 mm-rear
Pfadt (Adjustables): 32 mm-front / 26 mm-rear http://www.pfadtracing.com/
Pfadt (Adjustables): 35 mm-front / 29 mm-rear (Pfatty)
T1 (GM Racing): 38.4 mm-front / 27.5 mm-rear
Relative Stiffness (Provided by Pfadt http://www.pfadtracing.com/)
C5 base: 0.4
C5Z06 : 1
C6Z: 1.2
Pfadt Standard: 1.5
Pfadt Pfatty: 2.5
GM T1: 3
Here is the sequence of my suspension mods. Keep in mind that I race (road course.)
Starting Point... Z51
Then...
1. Lowered 1.5"
2. Hotchkis + Bilstein HD (not good the for street [bottomed-out]; not much improvement at the track)
3. Hotchkis + Bilstein Sport (less bottoming out; still not that great at the track)
4. Change tires to Nitto RII (huge improvement at the track, but still not adequate)
5. Hotchkis + QA1 Adjustable Shocks (adjustability provided better streetability, better rear drop for off-the-line, much better handling at the track)
6. T1 Bars + QA1 Shocks (fantastic set-up; car can out-handle Ferrari & Porsche in the curves)
Personally I like adjustable shocks so that you can optimize the setting for a specific need. Whether QA1, Koni, Mallet-Penske...adjustable provide better performance for trying to combine a street car with a track car. As far as Stabilizer Bars, no doubt in my mind...T1's offer great stability!
