Anothe CLB question
Old May 21, 2008 | 03:11 PM
L&M'sC5's Avatar
L&M'sC5
Default Anothe CLB question
I had the dreaded "column lock" while on vacation (earlier post). Fortunately I was able to get it unlocked. I have not bought a CLB for the car because I thought I read here on the "Forum" that it doesn't work on my year vette ('98 with manual transmission). Is this true or will a CLB work on my year vette??
Old May 21, 2008 | 03:12 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
call Corvettes Of Houston....
I dunno why it wont work on a 98...it works on my 99
Old May 21, 2008 | 03:14 PM
L&M'sC5's Avatar
L&M'sC5
Is yours an auto or manual transmission? I think it works on the auto but not the manual tranny>
Old May 21, 2008 | 03:15 PM
L&M'sC5's Avatar
L&M'sC5
Is yours an auto or manual transmission? I think it works on the auto but not the manual tranny.
Old May 21, 2008 | 04:00 PM
Crab's Avatar
Crab
Hey man, If you call and find out for sure ,can you please post it here ? Just bought a 98 with MN6 and really need to know also. Mine has had a recall performed but I'm not sure which one. It seems like none of them work
Old May 21, 2008 | 04:02 PM
GreensKeeperNJ's Avatar
GreensKeeperNJ
The first thing I installed in my 99 was a column lock by pass after hearing about all the problems people were having with the dealers fix and yes they are for 97-04 vettes and do work on 6 speeds.
Terry
Old May 21, 2008 | 06:56 PM
Oldvetter's Avatar
Oldvetter
COH CLB worked fine on my 1998 MN6.
Old May 21, 2008 | 07:29 PM
MagneticRed1977's Avatar
MagneticRed1977
Read the disclaimer in the CLB ads from Corvettes of Houston and Thunder Racing and make your decisions. I know 99 and up there is no problem.
Old May 21, 2008 | 08:02 PM
c3_enthusiast's Avatar
c3_enthusiast
worked on my 97 MN6
Old May 21, 2008 | 10:02 PM
TTK98's Avatar
TTK98
Got CLB from Thunder Racing--(98 MN6)--been on over two and a half years. No problems.
Old May 22, 2008 | 12:01 PM
L&M'sC5's Avatar
L&M'sC5
Thanks for the info. Good to know that it will work on mine!
Old May 22, 2008 | 01:31 PM
JC in XTC5's Avatar
JC in XTC5
CLB has absolutely nothing to do with what transmission you have.
Some people with earlier model year C5s seemed to have some problems with the CLB due to some differences in BCM timing or related difference that caused intermittent issues, but this was mostly anecdotal.
The issue with the transmission is whether GM would fully disable the CL - they would on A4 since there was still a shift interlock function by not on M6 because there is no other "safety" feature that immobilizes the car and hence would not comply with the letter of DOT requirements. Nonetheless the CLB works the same on either car.
You need to be careful on whether GM performed any recall procedures on the car since at least one of those procedures modified the wiring at the BCM which is not compatible with the CLB. Read the sticky for the details.
To Anothe CLB question
