Soooo, There is RWHP with these...
"Not worth installing, except of the sound" says one "expert". Those dual cone CAIs look nice but, Don't expect any HP 'cause of to much turbulance" posts another "expert".
Well, Corvette Fever is moding and dynoing a C5. The dual cone dynoed an extra 12 RWHP and 14 ft-lbs of torque. Then the catback added 7.65 RWHP and 1.34. TOTAL for the two 19.94 RWHP and 15.08 lb-ft of torque. No tune. Work done at Next Level Performance on a new Dynojet. I was surprised! You?
http://vette.automotive.com/61345/ve...on-tuning.html
Here's a dyno of cat backs and shorty headers, also from Vette Magazine...
http://www.vetteweb.com/tech/0501vet...ust/index.html
Note that the cat back alone does gain, 14 hp. However, that's at 5,600 rpm. The gains up to 4000 rpm are only 7 hp and 8 lbs ft of torque, so seat of the pants may not detect any improvement. If I'm accelerating from idle, you definitely won't feel the extra 3 hp that it produces down low.
Now, stacking mods may have a different effect as in the first article. It looks like one or two of these mods doesn't do much. Intake, x pipe, cat back and tune probably do add some good power.
The only problem is...
Intake: $300
X Pipe: $250
Cat Back: $800
Tune: $350
Total cost about $1700, maybe 30 rwhp if the article is to be believed
Long Tube Headers with catted x pipe: $1500
Tune: $350
Total cost $1850, 40 rwhp if not more.
That said, I'm going with the simple bolt ons.
I don't want to modify the pollution controls on the car and don't want any problems down the road with O2 sensors, throwing codes, etc. That eliminates long tube headers. Gears are out, since I don't want my mileage to drop 10% (great mod, though, I've had it done on other cars). Force induction is out because of cost and potential reliability issues.
The more radical your bolt ons the more your resale value suffers. Most people are not looking for a car with radical mods. In fact, many assume that it's been driven hard by it's owner if it's had too much done to it. I'm planning on selling my C5 after I drive it a few years and upgrading to a C6. That means simple bolt ons for me!
I'm just messing with you, I know the dyno can fluctuate. Significant performance gains won't come from simple bolt ons (LT/tune excluded). But every little bit helps. I know a port/polished TB won't give me any noticable horsepower, but it's better than no improvement at all and I want one anyway.
Our car has been on the dyno so many times over the years, that I should have a plate on the unit that says, "Partially paid for by Sully."
At times, we have run 3-4 dynos back-to-back and the fluccuations were as high as 8-10 hp from lowest to highest. Trust me...cat-back is for sound...the exhaust system past the cats is NOT restrictive.Remember, the value of a dyno is as a tool to tune the engine and determine the power curve of the car, unless the objective is just bragging rites. Also, keep in mind that peak HP numbers are not as important as the total area under the power curve. That is really what counts as your total power band. Our tuner actually lowered the peak HP of our 427, widen the TQ & HP curve and the car was noticeably faster at the track.
Our original stock LS1 was the first in the country to be re-tuned (what a mess that was!) and we picked-up ~15-20 RWHP, depending on which dyno result I use, just by adjusting GM's settings. For guys with an A4, the other advantage is using the information from dyno to set shifts points to the respective peaks and adjust TQ management / TC lock points. Adjusting these will provide better performance!
Great info and thanks for sharing
Thanks,Matt
Base @ 295.55 HP 305.20 Torgue
Filter @ 307.84 HP 319.94 Torque Increase across entire band
+Exhaust @ 315.49 321.28 Torque Increase above 4200
Just the messenger....
