Driver's side leak...@#%@#^#$!!!
Old May 27, 2008 | 08:58 AM
Maites's Avatar
Maites
Default Driver's side leak...@#%@#^#$!!!
So we have been getting quite a bit of rain in the DC area lately and I have had to leave the vette in the driveway. I had a windshield wiper problem so I had not driven it in a week or so and just watched it get rained on every day. I finally get back into the car an realize my entire driver's side floor/carpet is drenched! This has never happened before since I have owned the car. Anyone have any idea as to how this could havew happened? I have had the occasional drip leak from the targa but this was much more. Also my wiper problem could apparently be caused by having clogged udders. Could this have ended up in flooding my interior?? I need some sort of good answer!
Old May 27, 2008 | 10:27 AM
wit2pz's Avatar
wit2pz
Not really an answer, but a definite "feel your pain" post.
I get leaks on the passenger side when it rains, so I keep the car cover on it.
How would the udders affect the windshield wiper operation?
Old May 27, 2008 | 10:30 AM
magillicuttyjones's Avatar
magillicuttyjones
There is a pretty awesome thread on how to identify leaks and clear the various drains.. I don't have a link handy but it has a ton of pics and instructions. You'll have to search for it sorry :-/
My targa top was leaking when i washed it but I just reseated it and the leak went away luckily.
Old May 27, 2008 | 11:47 AM
Maites's Avatar
Maites
apparently if the udders clog then your windshield wiper motor gets flooded which makes the wipers lose their mind..before I pulled the fuse my wipers wouldnt turn off no matter what I tried.
As for this leak indentifying thread, I guess I will begin that search. If anyone finds it please post. I have never been good with forum searches. going to try now anyway
Old May 27, 2008 | 11:52 AM
moserbe's Avatar
moserbe
Old May 27, 2008 | 12:01 PM
Maites's Avatar
Maites
ok I found this post on leaks. However I am leaking on the driver side not the passenger. The bottom post shows a fix for passenger side...
http://forums.corvetteforum.com/show...ghlight=udders
Old May 27, 2008 | 12:10 PM
wildbadbill's Avatar
wildbadbill
Default I'd check the udders....
I had a problem with the wipers when went through car wash-found out the udders where clogged up and the wiper motor would stay under water going nuts.I cleaned them and no problem.
It's possible that you're getting water thru your fresh air intake in front of the windshield because of clogged udders....
Old May 27, 2008 | 02:26 PM
c3spdrcr20's Avatar
c3spdrcr20
You said udders.
Old May 27, 2008 | 02:57 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
They are on both sides.
Old May 27, 2008 | 03:12 PM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
I clean mine a couple of times per year and I went in Sat and pulled the darndest looking cratp out of udder 3.
Of the WSW motor area fills with water it can and will come up under the windshield and flow down the firewall into the drivers footwell.
Old May 30, 2008 | 03:18 AM
Deputy's Avatar
Deputy
It's in the sticky, strengths and measurements on the first page.
To Driver's side leak...@#%@#^#$!!!
