air conditioner problems
St. Jude Donor '11,'13
"I voluntarily took 60 days off from OT"
When my wife rides in the car and I run the AC she bawls a lot and says "It's FREEZING in here!!!"...Never noticed her tears to flood the floor
....so my bet would be your AC drain hose is plugged.....You'll have to raise the car to get to it....It's on the passenger side at the bottom of the firewall...You'll need to use a stiff wire or something similar and carefully clean whatever debris is plugging it......
It's normal for your AC to create moisture during operation, this moisture has to go somewhere, thus the drain hose.....
....so my bet would be your AC drain hose is plugged.....You'll have to raise the car to get to it....It's on the passenger side at the bottom of the firewall...You'll need to use a stiff wire or something similar and carefully clean whatever debris is plugging it......It's normal for your AC to create moisture during operation, this moisture has to go somewhere, thus the drain hose.....
Here is a link with pictures to help get an idea of what you will be looking for.
http://forums.corvetteforum.com/show...03&postcount=3
Hope this helps!
Hope this helps!
