Please Post Up Your Dyno's
Is that a hydraulic roller or a solid roller?
Eng. Mods Include:
Forged Stock Crank, Diamond Forged Pistons & Rods, AFR “Mongoose” Heads, Hardened Chrome-Molly Lifters, Comp. Duel Coil Springs, Titanium Retainers, LG Motorsports G5X4 Cam, Ported 90 mm LSX F.A.S.T. Intake w/ Nick Williams 90 mm Throttle Body & “Hurricane Intake System”, 38 lb Delph/Lucas Fuel Injectors, Meziere Electric Water Pump, ASP Under drive Pulleys.
Headers/Exhaust:
LG Long tube Headers (custom built in shop), 3” X-Pipe & Exhaust, , B&B Bullets w/ 4” Tips.
Transmission/Drive Train:
LG Motorsports Custom Built / Modified MN-12 6-Speed Tranny w/ B&M Ripper Short Throw Shifter,
Textralia “Aussie” 0Z-700 Clutch w/ Composite Light Weight Fly-Wheel, LG Motorsports Carbon Fiber Drive Shaft w/ Solid Aluminum Couplers,
DTE Stage ‘2’ Differential w/ 3.90 gears, Hardened Output Shaft, & Billet Pinion Shaft Support.
DTE Differential Strut/Brace Support Cradle
Brakes: BAER EaradSpeed +2 Rotors
Wheels: FIKSE ‘Profil 10’ Series 3pc. Wheels
Fronts- 18” x 9” Rears- 19” x 10.5”
Tires: Michelin Pilot Sports
Fronts - 275/35/18” Rears - 295/30/19”
God Bless,
2KLEN4U
Eng. Mods Include:
Headers/Exhaust:
The before was with blackwing, aluminum intake, Corsa touring and X pipe. DTE installed Dynatech LT headers, high flow cats and X pipe, replaced the intake with the stock and put in a 160 therm then dyno.
My compression is only 10:33 due to unmilled 205/66cc AFRs and running with a .54 Gasket. I also dont have a Pulley
I just added bigger injectors and put on the LG Pros for more Torque and havent had it dynod since then but my numbers before I did the recent changes were 414/390.. I was a bit higher then that but we pulled it back for a more conservative tune.
I know if I milled to 59cc, got a .40 gasket,I would be at a 11:7 compression and if I added a pulley that I would most likely be at a 460/440 set up. Maybe at some point but for now, it gets me exactly what I need.
I am shocked to see 500 on a STOCK block N/A car.
RWTQ- 361.3 @ 3800rpm.
Not bad for a 99 that has 345 at the crank..........
BTW, the before dyno tune #'s are on the right & the after on the left. I'm happy with the "stock" results.
Why is there no graph with your dyno tune results? You should have gotten one that shows where the HP and Torque cross on the curve.
2KLEN4U
510rwhp/468tq
2KLEN4U
