How to change disk in 12 cd player?
Old May 29, 2008 | 09:21 PM
cookrent's Avatar
cookrent
St. Jude Donor '08
Default How to change disk in 12 cd player?
Mine seams to play disk 12 over and over. Read manual and it tells to change tracks. Going on trip this summer, would like to get to the other 11 CDs
Old May 29, 2008 | 09:24 PM
Mike Mercury's Avatar
Mike Mercury
Select the Random mode... that'll get you to another disk.
Old May 29, 2008 | 09:28 PM
65GGvert's Avatar
65GGvert
Press the number 5 button, that selects the next disk. It's in the owner's manual. (That is, if it also has an indash cd, I didn't look up the button for in dash cassette, but it's in the manual, too)
Old May 29, 2008 | 09:34 PM
cookrent's Avatar
cookrent
St. Jude Donor '08
In dash does not work will try random mode. Thank you
Also try 5 button
Old May 30, 2008 | 07:18 AM
65GGvert's Avatar
65GGvert
Just so there's no misunderstanding, here's the copy from the manual. If this doesn't work, either your unit is bad, or the disks are upside down or not being recognized (except for number 12)
Operating the Trunk-Mounted CD Changer with the Radio with Cassette
If an error appears on the display, see "CD Messages" later in this section.
1 PREV (Previous)
Press this pushbutton to go to the start of the current track if more than eight seconds have played. If this pushbutton is held or pressed more than once, the player will continue moving backward through the CD.
2 PROG (Program)
Press this pushbutton to select the next CD in the magazine. If a CD cannot be played, its number will be skipped when selecting CDs while using this pushbutton
3 NEXT
Press this pushbutton to go to the next track. If this pushbutton is held or pressed more than once, the player will continue moving forward through the CD.
REV 4 (Reverse)
Press and hold this pushbutton to quickly reverse within a track. Release the pushbutton to play the passage. The elapsed time of the track will appear on the display.
5 (Dolby)
This pushbutton has no function when playing a CD.
FWD 6 (Forward)
Press and hold this pushbutton to quickly advance within a track. Release the pushbutton to play the passage. The elapsed time of the track will appear on the display.
RECALL
Press this button to see what track is currently playing. Press it again within five seconds to see how long the track has been playing.
SEEK
The left arrow works the same as the PREV pushbutton and the right arrow works the same as the NEXT pushbutton.
P.SCAN (Preset Scan)
Press this button to listen to the tracks on all of the CDs in random, rather than sequential, order. RDM will appear on the display. Press this button again to turn off random play.
AM/FM
Press this button to listen to the radio when a cassette tape or a CD is playing. The inactive tape or CD will remain safely inside the radio for future listening.
TAPE AUX (Auxiliary)
Press this button to play a CD when listening to the radio. Press this button to switch between playing a tape in the cassette tape player and playing a CD in the trunk-mounted CD changer, if both are loaded.
Operating the Trunk-Mounted CD Changer with the Radio with CD
1 PREV (Previous)
2 RDM (Random)
Press this pushbutton to play the CDs in random, rather than sequential, order. RDM will appear on the display. Press this pushbutton again to turn off random play.
3 NEXT
REV 4 (Reverse)
Press and hold this pushbutton to quickly reverse within a track. Release this pushbutton to play the passage. The elapsed time of the track will appear on the display.
5
FWD 6 (Forward)
Press and hold this pushbutton to quickly advance within a track. Release this pushbutton to play the passage. The elapsed time of the track will appear on the display.
RECALL
SEEK
AM/FM
Press this button to listen to the radio when a CD is playing. The inactive CD will remain safely inside the radio for future listening.
CD AUX (Auxiliary)
Press this button to play a CD when listening to the radio. Press this button to switch between playing a CD in the CD player and playing a CD in the CD changer, if both are loaded.
To How to change disk in 12 cd player?
