Question about HUD
Old May 30, 2008 | 08:58 AM
Einn's Avatar
Einn
Cruising
Default Question about HUD
If anyone has seen some of my prior posts, i do not currently own a corvette (dad is gettin' there though, gettin' most of the money together! yay!).
We have been looking actively in the Raleigh area of NC for all C5 coupes, auto or manual. The thing is, pretty much all of them (except 1) does not have the HUD. After personally test-driving a 'vette that has had the HUD, my dad and i are determined to purchase one that has it in it. My question though is, if we find the perfect 'vette (really good price, all other options, good color) but no HUD, how much is it typically to install afterwards? I've seen previous posts about it, but what is the total cost after everything is done? We might be willing to settle for one that does not have the HUD, providing that it's not too costly afterwards.
Thanks for reading,
Einn
Old May 30, 2008 | 09:01 AM
damilleniumboy's Avatar
damilleniumboy
I think it's expensive to install, plus why would you want two sets of gauges when the ones in the instrument cluster are so nicely done. It is nice to have, but if the car doensn't have it, it will not hurt the looks of the car at all IMHO.
Old May 30, 2008 | 09:02 AM
damilleniumboy
My car doens't have the z51 suspension which I will upgrade in the future, or the mn6 but I can live without both of them.
Old May 30, 2008 | 09:49 AM
Pseudomind's Avatar
Pseudomind
Thanks for reading,
Einn
I am not certain about this as I do not know what GM installs (Same windshield for non-HUD as HUD), but I think a non-HUD car will need a different windshield for starters. Something about a special optical coating where the HUD displays.
Old May 30, 2008 | 09:55 AM
steve8's Avatar
steve8
Some have said the windshield is an issue, a lot have said it is not??
I believe it can be done for about $400, not changing the windshield.
Old May 30, 2008 | 09:58 AM
Ron MN Blue's Avatar
Ron MN Blue
My brother installed HUD in his '99 FRC. He did it himself after buying the parts from a Forum vendor. He did not change the windshield, it works fine with the original windshield. I think he spent in the 5-6 hundred dollar range. The cost was higher than he planned as his '99 is an early VIN# and needed a part that later models have installed. I believe this is accurate info.
By the way, he really likes the HUD in the car.
Old May 30, 2008 | 12:03 PM
Deke736's Avatar
Deke736
When I was looking for my Vette I really wanted HUD as well. I found one that has it installed (2000 Vert), but honestly I hardly ever use it. You can also forget about seeing it in bright sun or if you wear polarized sunglasses (it is very dim). I think if you find a great car that has everything eles you are looking for in it, get it- HUD or not!
Good luck on your search!
Old May 30, 2008 | 12:15 PM
Mike McCoy's Avatar
Mike McCoy
Late '99s and up are HUD ready. It only takes the projector an a specially made 11 pin harness to work. No reprogramming is necessary. A forum vendor has this conversion available as a kit. I did my car, '99 vert, and it worked great. His instructions are very detailed and easy to understand. You DO NOT need a HUD windshield. The regular windshield works fine, even in direct sunlight. I think I paid about $250.00- 300.00 for the kit from him. I'm not positive about that though. Early '99s and older need a HUD compatable insturment panel and reprogramming of the speedo. This adds several hundred bucks to the job. The vendors name was Josh as I remember.
Old May 30, 2008 | 01:54 PM
grayfox2424's Avatar
grayfox2424
I installed the HUD in my 1998 Vette..bought the parts on the big auction site ...Projector,HUD instrument cluster,connecting cable ,dash bezel for about $250 total. Sold my old cluster for $75.00...also just cut the opening in your current dash and glue on the bezel..Whole effort took one afternoon. Very easy to do .I shhould tell you that you do have to remove the entire dash assy and the assoc mouldings but if you follow directions it is not difficult. Don't need the HUD windshield...stock windshield works fine.
If you take your Vette to the Daytona track or where ever and at 140mph or so it is a secure feeling not to have to take your eyes off the track to see you speed.
Old May 30, 2008 | 02:37 PM
mikes04z's Avatar
mikes04z
The first C5 I ever drove was a 2001 Vert with HUD. I knew I was in the market for a C5Z and after 2001, HUD came as standard equipment on the Z's. Regardless, I knew whatever car I ended up with would have to have it. Sure, you can't always see it if you're driving in direct sunlight, but I honestly can't tell you the last time I looked down at my actual speedometer to see how fast I was going or to check my gas gauge. When its all right in front of you, you just don't want to take your eyes off the road. Then the fun part - try getting in your wife's car that doesn't have HUD and remind yourself you have to look down!
Anyway, not sure of the install process but it seems others here are familiar and have done it. Since its obviously doable, go find the car you want and focus on that - not the HUD. If it has it, great. If not, looks like you can always add it later.
Old May 30, 2008 | 03:13 PM
ALVETTE00's Avatar
ALVETTE00
I wouldn't let the HUD prevent you purchasing a good cond vette.
Personally, I don't like the HUD...find it distracting.
But others love it...different strokes for different folks!
Old May 30, 2008 | 05:28 PM
Drumss's Avatar
Drumss
I was desperately looking for a vette with the HUD, but couldn't find one that had it, or the performance axle that was within a reasonable distance, or in my price range.
So I bought a really clean 2004 Coupe without the HUD or performance axle, and honestly I don't miss either at all. My friends all have Z's so they have all the bells & whistles, but for the driving that I do, I'll never tap the limits of this car.
I've toyed with the idea of retrofitting a HUD kit, but I'm worried that I'm not that handy...
To Question about HUD
