Ok, i have a 3 gauge pillar pod,now im going with a air/fuel wideband,fuel pressure gauge.What would be another good one to go with that is easy to install.I tried to go with a water temp gauge but it will not fit in my head.The sensor will but i cant screw the bolt that holds the sensor into the head.I tried to get an adapter but it was to big also,so the water temp gauge is out.Can someone help me with this please............Thanks dan
