Coolant/Thermostat change
Old Jun 1, 2008 | 12:04 PM
Jimbad's Avatar
Jimbad
St. Jude Donor '06-'09-'10-'11
Default Coolant/Thermostat change
Hi, Everyone,
I recently changed the coolant on my '03 and in the process I was provoked to write this tip: Make sure that your new thermostat is functioning properly before you install it. You can do this by placing it and an appropriate thermometer in a pan of water on your stove. Heat the water and keep checking the thermostat and the thermometer to ascertain that the 'stat opens at the specified temperature. (I use a pair of tongs to take the 'stat out of the water so I can clearly see the opening.)
I've read a number of coolant articles on the Forum and have not seen this basic step included, so I want to pass it on. A new part of any type can malfunction from the "git-go".
Jim
Old Jun 1, 2008 | 05:16 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Default Sorry
Ive posted this tip atleast a hundred times over the last 7 years... along with the proceedure to swap out the thermostat in five minutes without draining the coolant, and loosing less than a pint of coolant, that is easily recovered.
Old Jun 1, 2008 | 10:38 PM
Jimbad's Avatar
Jimbad
Sorry, Evil Twin,
I did come across even one of your hundred mentions during my "coolant" search.
Jim
Old Jun 1, 2008 | 10:47 PM
cozer1's Avatar
cozer1
Old Jun 2, 2008 | 12:21 AM
tlc0706's Avatar
tlc0706
Thanks Jim for the reminder... and Evil...I'll do a search I promise..
Old Jun 2, 2008 | 06:21 AM
Thanks for the reminder.
To Coolant/Thermostat change
