[Z06] Trunk Badge replacement?
Old Jun 1, 2008 | 08:23 PM
Internets_Ninja's Avatar
Internets_Ninja
Default Trunk Badge replacement?
I was washing my Z06 yesterday and I noticed the black flags side of hte trunk emblem is missing!
I only need the black flags part, but I doubt you can buy that by itself.
Does anyone know where to get a new emblem from and the best way to remove/reattach the new one?
Old Jun 1, 2008 | 10:52 PM
FourG63 97GST's Avatar
FourG63 97GST
leave it off, less drag and weight
Old Jun 1, 2008 | 10:56 PM
rickko's Avatar
rickko
Well I suppose its glued on. Now if it is using the same glue used to hold the BSM's to the doors then I'd try applying a little heat (maybe just holding a hot light bulb close to it), then prying up an edge (maybe not) and use fishing line to cut through the glue.
That's how I got my BSM's off.
..rickko..
1SikVette's Avatar
01SikVette
Former Vendor
Should see a .000000000000000000001 difference in 1/4 times LOL.
To the OP, check out your local dealer for a whole new emblem.
Old Jun 2, 2008 | 12:02 AM
toncarr's Avatar
toncarr
IMO - If you can't glue it back on, just it leave it off... it's much cleaner looking without it.
http://forums.corvetteforum.com/show...ighlight=naked
Old Jun 2, 2008 | 12:54 AM
bullitt4110's Avatar
bullitt4110
I took mine off and I think it looks a lot better w/o it.
To Trunk Badge replacement?
