A/C problem need help!!!
Old Jun 2, 2008 | 07:23 PM
PashaCorvette's Avatar
PashaCorvette
Default A/C problem need help!!!
Hi Guys
Recently I am having problem with the blow of the ac unit.When I try to turn all the way up although the screen shows all the bars but it doesn t blow the air that much at all, it blows like it`s on 2nd or 3 rd level and i am already having low led light problem and sometimes it turns it self off without pushing off button.The air is cold though just it doesnt wanna blow strong.I don t know if the unit or the compressor has the problem any suggestions pls.
Thnks
Pasha
Old Jun 2, 2008 | 08:55 PM
PashaCorvette
Anybody
Old Jun 2, 2008 | 09:22 PM
c5streak's Avatar
c5streak
Is the air coming out of the vents that are selected? Do the driver and pass temp controls work properly? If yes, then it could be a problem with the blower motor or the blower control module. If no, then you may have a blend door actuator problem.
Also check for any codes in the DIC, and post them here if you have any.
Old Jun 2, 2008 | 09:31 PM
PashaCorvette
Thnks C5streak will check the codes to night
To A/C problem need help!!!
