Corvette engines CAN run without coolant?
Old Jun 4, 2008 | 05:18 PM
BobbyG's Avatar
BobbyG
St. Jude Donor '06-'07
Sounds like my Z06 is equipped for just about anything, even the desert. I wonder if my next assignment will be in the middle east....
Old Jun 4, 2008 | 05:43 PM
Oldvetter's Avatar
Oldvetter
IF you use this feature, the owner's manual says to change the oil after this.
Old Jun 4, 2008 | 07:21 PM
Dominic Toretto's Avatar
Dominic Toretto
Actually all engine CAN run without coolant... but I wouldn't do it
-Alex
Old Jun 4, 2008 | 07:25 PM
flyzlow's Avatar
flyzlow
Default I guess it doesn't work on the C4...Damm!!
dobewillie's Avatar
dobewillie
that's solid info
Old Jun 4, 2008 | 07:27 PM
71vetteinva's Avatar
71vetteinva
Cylinder cutoff when the car overheats is now somewhat common, not when the C5 was new, which makes it ahead of it's time! I had an '05 Focus for a few years and it had the same feature.
Old Jun 4, 2008 | 07:39 PM
Robls6's Avatar
Robls6
Originally Posted by c5streak
For some reason, when I read this^^^
I picture this:
Old Jun 5, 2008 | 03:12 PM
dankhts's Avatar
dankhts
Awesome info .... I knew that the engine in my STS Caddy is advertised to run up to 50 miles without coolant and without harm, even though I'd not like to try it... part of the reason for the ability is, according to a GM engineer, thanks to the larger oil capacity, VS other engines, which I can see somewhat, and also to the use of Dexcool, which I can't see, but he claims it impregnates the bock......
I guess the vette engines should have the same features....
Old Jun 5, 2008 | 03:26 PM
Mongolink's Avatar
Mongolink
Originally Posted by LMH4C5
Kind of like the human body. When you turn 60 your body feels like it is running on half of its cylinders.
Hell I just turned 50 and I dont think my compression stroke is what it used to be
How's that saying go
" I'm not as good as I once was.. but I'm as good once as I ever was"
Old Jun 5, 2008 | 03:37 PM
vetterlatethannever's Avatar
vetterlatethannever
Old Jun 5, 2008 | 10:43 PM
RoadReady's Avatar
RoadReady
Don't know about no coolant, but it operates with a non-functioning water pump. Man, is that security or what!!
Old Jun 5, 2008 | 11:33 PM
Didn't know this either. Learn new things here every day.
Old Jun 6, 2008 | 12:02 AM
  #33
vettelover84's Avatar
vettelover84
Very interesting!!!! But I am not going to try it....
Old Jun 6, 2008 | 03:45 AM
  #34
Old Timer's Avatar
Old Timer
I kinda wonder if you had an A4 (auto trans) what it would look like after 50 miles without any radiator cooling?
Old Jun 6, 2008 | 09:09 AM
  #35
opz28's Avatar
opz28
I picture this:
I just spit coffee everywhere
Old Jun 6, 2008 | 09:18 AM
  #36
vrybad's Avatar
vrybad
Originally Posted by Buckskiner
read yer owners manual
is spelld "manyewl"
git it raht
Old Jun 6, 2008 | 09:55 AM
  #37
DPG's Avatar
DPG
St. Jude Donor '06
dont wanna ever try it, but good to know that you can limp it along a bit further to safety.
To Corvette engines CAN run without coolant?
Old Jun 6, 2008 | 10:50 AM
  #38
Chemdawg99's Avatar
Chemdawg99
St. Jude Donor '12 thru '21
Good information
On a side note: Enquiring minds want to know.....Buckskinner, are you for real? You gotta be a Yale graduate or and MIT grad to consistently type your posts in "hillbillyeze" the way you do.
Old Jun 6, 2008 | 11:20 AM
  #39
CharlieB1979's Avatar
CharlieB1979
Originally Posted by DefenderC5
On a serious note though, I wonder if you can trick the PCM to engage this feature while driving on the highway regardless of temps... via in-line switch or something (not crazy enough to try it on mine obviously). Would it work similar to the other V8s on the market that shut down half their cylinders as well? Of course, that 35mph limit would be a little annoying...
I wouldn't even dare. The reduced power is a result of the lesser number of cylinder use. I know that Chrysler cars do this, but they're engineered for that purpose, not as an emergency backup. The engine limits what it can do, likely creating a new "top engine performance threshold". 55MPH might be pushing too hard for the reduced power of the engine.
Think of it as driving around on a donut tire....theoretically it's there for you to drive on, but definitely not meant for speed or extended use.
To trick the engine into thinking that it's in this power-saver mode could wind up doing far more bad than good as a result, and what would have cost an extra $25.00 at the pump, may cost you $1,500+ in the repair shop.
Old Jun 6, 2008 | 02:20 PM
  #40
corvettebob1's Avatar
corvettebob1
Originally Posted by SmoothFRC
I immediatly thought of that also, but reading a bit more on how the "active fuel management" works, it actually disengages the lifters (via selinoids i believe) to stop the intake and exhaust valves from working. It actually uses the compression and decompression to assist with the rotating mass, vs just pulling off 4 spark plug wires, the other 4 cyl would have to work pretty hard to deal with the compression stroke, etc.
I don't believe this is correct if you disengage the lifters and the valves stop opening in 4 cylinders the other 4 will have to work pretty darn hard the move those pistons.
If you don't believe me go and take the rockers off 4 cylinders and try to turn the engine over by hand!
