Headers question(s)
Old Jun 4, 2008 | 09:54 AM
VinnyT's Avatar
VinnyT
Default Headers question(s)
Which headers will bolt on to the factory pipe locations? Also how difficult are they to install?
V
Old Jun 4, 2008 | 09:56 AM
Berger6696's Avatar
Berger6696
Hi Vinny,
I'm starting to explore this too so I will be paying close attention to this thread.
Are you stock? I seem to remember you installing Vram right before I did.
Old Jun 4, 2008 | 09:59 AM
VinnyT's Avatar
VinnyT
Yup, pretty much stock. I am planning on getting the cats "cleaned" out to go along with the headers and Granatelli cat-back already on the car.
Old Jun 4, 2008 | 10:09 AM
nickolbag's Avatar
nickolbag
Why not get an X pipe with high flow cats?
If you want to keep the stock H pipe you gotta go with shorties, I believe.
slowtealz28's Avatar
slowtealz28
Texas speed will bolt up to the stock h pipe
Old Jun 4, 2008 | 10:13 AM
VinnyT's Avatar
VinnyT
Well, I will as time/money permits. I know that Borla has an X-pipe that bolts to the stock manifolds. So, I want to start with the headers that can bolt to the stock H-pipe, then later get the Borla X-pipe to bolt-on, then cats.
Old Jun 4, 2008 | 10:33 AM
Vega$Vette's Avatar
Vega$Vette
All long tube headers will require changing the mid pipe for 100% bolt on install. If using the stock mid pipe it will have to be cut and welded to fit the LTs.
Only Shorties are made for bolt on to stock mid pipes.
Old Jun 4, 2008 | 10:44 AM
VinnyT's Avatar
VinnyT
Is there a performance difference between the Shorties and Long Tubes?
To Headers question(s)
