[Z06] will it fit?
Old Jun 5, 2008 | 11:30 AM
03blackZ06's Avatar
03blackZ06
Default will it fit?
Im tring to make a homemade dragpack set up. Im wondering if 17x11 zr1 wheels witha 50+ mm offset will fit on the rear of my z06? Thanks mike
Old Jun 5, 2008 | 12:06 PM
TM-Z06's Avatar
TM-Z06
Yes - they'll fit
Old Jun 5, 2008 | 01:44 PM
03blackZ06's Avatar
03blackZ06
and the will clear the brakes and no spacer needed? thanks mike
Old Jun 5, 2008 | 02:03 PM
TM-Z06's Avatar
TM-Z06
They easily clear stock brakes.......no spacers needed. A few guys around here use ZR-1 17x11's on all 4 corners for auto-x wheels
Old Jun 5, 2008 | 08:12 PM
DT's Avatar
DT
Yes! A guy at Roebling had that very setup with some Khumo's. Said it ran good (he was very quick) and the cheaper cost of the 17" track rubber made a pretty big difference over the course of a season.
Looked pretty great too.
Old Jun 6, 2008 | 01:33 PM
03blackZ06's Avatar
03blackZ06
will the 17x9.5 with a 56 mm offset fit?
Old Jun 6, 2008 | 01:47 PM
DT's Avatar
DT
FYI, here's a good article I had bookedmarked about using C4 GS spec wheels on a C5. The guy I mentioned above was actually running those an not OEM spec ZR1 wheels.
AFAIK, C4 GS wheels are 17x9.5 with 56mm offset on front and 17x11 with 50mm offset on rear. The OEM C4 ZR-1 rears are 36mm (and would stick out quite a bit, the GS wheels tuck decently, even without the add-on fender flares).
http://www.vetteweb.com/tech/0301vet...ims/index.html
Hope that helps!
Old Jun 6, 2008 | 01:51 PM
Labold's Avatar
Labold
How about a set of 17" fronts off a 98? I have access to free set that I would like to use for drag radials.
Old Jun 6, 2008 | 03:08 PM
TM-Z06's Avatar
TM-Z06
Only the calipers (painted) and brake pads are different between the C5 and C5Z. All 17" C5 front wheels will fit.
Old Jun 6, 2008 | 03:47 PM
Labold's Avatar
Labold
What I meant was will the 17" fronts fit on the rear of my car?"
Old Jun 6, 2008 | 05:46 PM
TM-Z06's Avatar
TM-Z06
My answer remains the same - front or back. However - the 98 rims are only 8" wide. You're not going to get much rubber on them
To will it fit?
