[Z06] Key fob issue
Old Jun 7, 2008 | 10:57 PM
Z-THREAT's Avatar
Z-THREAT
Default Key fob issue
When I use my key fob to lock my doors or set the alarm, only the passenger side locks. Any ideas?
Regards-
John
Old Jun 9, 2008 | 02:55 PM
only59's Avatar
only59
ok, silly question..
Does the driver side LOCK with the door panel switch ?
The fact that ONE door lock does work ( FOB wise) leads me to lean Driver SIDE relay or Fuse issue. Thats where I would start.
Old Jun 9, 2008 | 04:45 PM
Z-THREAT's Avatar
Z-THREAT
Good question. The drivers side door lock will not lock with fob or switch on door, only manually. However it will unlock with fob or switch on door. Go figure! Any suggestions?
Best Regards-
John
Old Jun 9, 2008 | 05:10 PM
TM-Z06's Avatar
TM-Z06
http://forums.corvetteforum.com/show....php?t=1606865
Old Jun 9, 2008 | 10:31 PM
Z-THREAT's Avatar
Z-THREAT
Thanks for the help!! I'm leaning towards a relay, after reading the suggestions.
Best Regards-
John
Old Jun 10, 2008 | 03:00 AM
striper's Avatar
striper
I had exactly the same thing occur in my car. It is the door control module. It's easy to replace and once done you will have no more problems. If you are out of warranty, the problem is the relays that are in the module. They are replaceable if you know how to disassemble it and are good at soldering. Some on the forum have done this. I was in warranty when it happened so I just got a new part.
To Key fob issue
