HUD install on a 2000
Old Jun 8, 2008 | 11:48 AM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Default HUD install on a 2000
Ok I have done the searches and it doesn’t seem all that hard. but does anyone have all the GM part numbers for the complete install.
Old Jun 8, 2008 | 12:07 PM
c5streak's Avatar
c5streak
Two members you can contact that will have all the info you need.
"PaceThis"
and
"Steve Doten"
Josh sells and installs, Steve is an authorized installer for Josh.
PM either one for the full scoop.
Old Jun 8, 2008 | 05:18 PM
davek 515's Avatar
davek 515
I put HUD in my '99 frc in January and very happy with the finished product, you will be happy with your end result. A list of the parts: bezel #10425223
switch# 12198648
display projector#10279814
I think these numbers are correct but check first.
Also the installation easy easy just take your time and get a piece of cardboard and push all screws and etc. into the cardboard and label also take pictures. BEST OF LUCK!
Old Jun 8, 2008 | 05:30 PM
JeepTJ's Avatar
JeepTJ
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
Pacethis has a great write up on doing the install.
Here are some pics of mine.
The fun part.
This looks worst then it is.
Projector in
Good luck on your install. It is a SWEET mod.
Old Jun 8, 2008 | 07:56 PM
EDenney's Avatar
EDenney
I'd probably have a heart attack and die right on the spot if I ever saw my Vette looking like that . All the reassurances in the world that it'll all be fine once it's back together, wouldn't do a thing to calm my nerves .
Old Jun 8, 2008 | 09:11 PM
Nowhere Man
ok thanks that is what I was looking for. is the dash pad easy to take out and put back together. this may be a winter project.
Old Jun 8, 2008 | 09:26 PM
Nothing else to add except you will love the HUD.
Old Jun 8, 2008 | 09:35 PM
travelingypsye's Avatar
travelingypsye
I did mine by myself complete in 2.5 hrs. Follow the instructions from Pacethis & you will be fine.
It really is easy. It just looks bad. Josh has a complete step by step instructions on the install.
To HUD install on a 2000
