MGW race shift knob
Old Jun 9, 2008 | 02:44 AM
SkyWarp's Avatar
SkyWarp
Default MGW race shift ****
Does it have a set screw on it or just threaded? thanks
Rob
Old Jun 9, 2008 | 08:22 AM
jdreg's Avatar
jdreg
set screw
Old Jun 9, 2008 | 08:32 AM
LMH4C5's Avatar
LMH4C5
St. Jude Donor '08-'09-'10
National Champs Gators 4 St. Jude '09
Threaded and a set screw.
Old Jun 9, 2008 | 08:49 AM
JohnTheStigGalt's Avatar
JohnTheStigGalt
The shift **** will work on a stock C5 shifter OR an aftermarket shifter, but WILL NOT work on the stock C6 shifter. The set screw is on the front, not the side like the C6, and is only designed to prevent further rotation once you tighten the ****'s threaded polyurethane insert on the shifter. Frankly, I cranked mine down as far as it possibly would go and it was TIGHT, so I think the set screw is probably overkill, but no reason not to use it.
Vaughn
Old Jun 9, 2008 | 04:15 PM
WKMCD's Avatar
WKMCD
Vaughn
Kevin
To MGW race shift knob
