Tranny fluid
Old Jun 9, 2008 | 08:00 PM
greg252's Avatar
greg252
Default Tranny fluid
Hello, I went to my garage owner and I wanted to change my oil transmission. He have a machine which makes the flush of the liquid with also a soap or a cleaner which cleans the system. My question is, do I have to change the filter and to remove the pan to?
TY
Old Jun 10, 2008 | 09:03 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
It's always a good idea to inspect for metal chips and friction material that might be at the bottom of the pan.
You can tell much more about it's overall condition by removing the pan.
Even with a power flush,I would replace the filter too.
Old Jun 10, 2008 | 09:12 AM
bucwheat's Avatar
bucwheat
My question is ,if you drop the pan where do you put the new fluid in at?Trans cooler?
Old Jun 10, 2008 | 10:13 PM
greg252's Avatar
greg252
I guess you fill by the drain plug ???
Old Jun 10, 2008 | 10:17 PM
robsc501's Avatar
robsc501
Hi there,
with greg252 drain plug.
robsc501
Old Jun 10, 2008 | 10:20 PM
waunavet's Avatar
waunavet
St. Jude Donor '20
Just had my 1999 done at 32K.
Old Jun 11, 2008 | 12:59 AM
4DRUSH's Avatar
4DRUSH
Not a big fan of flushing the trans. I say let the filter collect any lose particles and let the fixed particles fixed. Just drop the pan (clean the magnets on bottom of pan) and change the filter. Most important is to refill the trans compltetly. In order to do so you need to run the trans thru the gears and refill (several times if necessary)
Old Jun 11, 2008 | 10:26 AM
Quicksilver Vert 01
There is NO drain plug on the C5 transmission pan.
The plug on the left side of the the pan is the fill level plug.
Old Jun 11, 2008 | 11:27 AM
Mike McCoy's Avatar
Mike McCoy
When refilling the trans the engine must be running or you will not get the correct amount of fluid in.
Old Jun 11, 2008 | 03:09 PM
vetter79's Avatar
vetter79
But be careful, there's a hot tail pipe right there too!!
To Tranny fluid
