Blackwing intake
Old Jun 9, 2008 | 08:36 PM
vetter79's Avatar
vetter79
Default Blackwing intake
Anybody have any idling problems (or anything for that matter) on they're stock LS1 after installing a BlackWing intake system? Should a smooth coupler used w/ the "Wing" to further enhance its performance?
Any help is always appreciated. Going on a 800+ mile trip next month so hoping I can get a wee bit higher mileage w/ a better air intake setup.
Old Jun 9, 2008 | 08:41 PM
thetaxman's Avatar
thetaxman
smooth coupler does not work
my blackwing had no issues
Old Jun 9, 2008 | 09:04 PM
cozer1's Avatar
cozer1
dont have any troubles here. works great with my blackhawk
Old Jun 9, 2008 | 09:07 PM
rickko's Avatar
rickko
I installed a smooth coupler and a velocity stack behind my blackwing. Neither has caused any problems over the past 3 yrs since installed. The trip mileage is great depending on whether or not I run into headwinds.
I also installed Ti exhausts to help with the overall flow.
..rickko..
Old Jun 10, 2008 | 12:38 AM
tlc0706's Avatar
tlc0706
Nothing on mine...Might unhook the battery and then drive a little to "train the brain".....
Mine came with coupler
Old Jun 10, 2008 | 06:16 AM
Grim Reaper's Avatar
Grim Reaper
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19
No issues with mine since install. Also came with coupler, running B&B PRT catback.
Old Jun 10, 2008 | 06:27 AM
rrhvette's Avatar
rrhvette
No issues with mine either........Running Borla Stingers......
Old Jun 10, 2008 | 09:06 AM
itzza427's Avatar
itzza427
Mine came with one on it,,I added Corsa touring and it runs great.. At the Mid West Nationals Valvoline used my car for they're dyno display. They did 13 runs(3 the first time then 5 more sets of 2) The ECM "learned" to run at WOT , adjusted the WOT air fuel and it picked up 15 hp and 20 pound ft from the first set to the last sets(hp from 323..51 to 338.92---tq from 324.76 to 345.91) Big thing is DON'T OVER OIL the material. Then take it ti test and tune night at the strip and give it a bunch of WOT runs and feel the difference! Right after the dyno Gateway International had a test and tune night and my final pass was 13.08/110.23 on stock run flats(and this was the first time out with this car,just bought it in Jan) enjoy your car!!
Old Jun 10, 2008 | 09:15 AM
bucwheat's Avatar
bucwheat
No problems here.did you hook everything back up correctly?
Old Jun 10, 2008 | 03:45 PM
Rou-Rou 03's Avatar
Rou-Rou 03
5yrs no problem here
Old Jun 10, 2008 | 03:56 PM
Herringchoker's Avatar
Herringchoker
From: "Man been singin' the Blues, since he began to till the ground"...Vancouver, USA WA.
No problems here, also added a Hi-flow MAFS & air bridge (2+yrs.) Much better throttle response. JOE
Old Jun 10, 2008 | 04:09 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
Make sure you double check everything to make sure it is "sealed" up good...meaning the clamps are correct, the coupler is properly on the throttle body. I have seen people have a loose connection at some point, or not have the Maf hooked up right and it will cause problems. Also if you somehow got oil on the Maf sensor or touched those wires, they are very sensitive and could cause the car to run rough if they are screwed up.
Old Jun 10, 2008 | 06:20 PM
vetter79's Avatar
vetter79
Just ordered one from Corvettes of Houston, now we'll see!
Old Jun 10, 2008 | 06:22 PM
El Paso Vette's Avatar
El Paso Vette
Mine works just fine. No problems at all. I did install a smooth coupler.
Old Jun 10, 2008 | 06:43 PM
jrose7004's Avatar
jrose7004
Nope, I've had my Blackwing for a year with no problem.
Old Jun 10, 2008 | 06:53 PM
vettelover84's Avatar
vettelover84
Old Jun 10, 2008 | 10:18 PM
I used the stock coupler with my Blackwing - no problems at all with the idle or anything else.
To Blackwing intake
