GM bra question
Old Jun 10, 2008 | 09:02 PM
IrishMac's Avatar
IrishMac
Moderator Emeritus
Gone, but not Forgotten
Cruise-In 5, 6, 8 & 10 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09
Default GM bra question
Any of you ever cut out the plastic inserts for the cold air intakes? I have a Blackwing and want to make sure it breathes to its fullest.
TIA.
Old Jun 10, 2008 | 09:05 PM
moserbe's Avatar
moserbe
I punched out a bunch of 1" holes in the plastic for my CAI Vararam.
Old Jun 10, 2008 | 09:51 PM
Charlie from Cherry Hill's Avatar
When I had a GM bra, I cut oblong holes in front of each fog light screen. I had earlier replaced the fog light screens with ones that had holes it them to allow air in. I used a drinking glass as a template on each end of the area I was going to cut out and a straight line between the half-circles. I seemed to work well. I have since purchased a SpeedLingerie bra, which comes with a cutout. My signature shows the old GM bra.
Old Jun 10, 2008 | 10:48 PM
IrishMac's Avatar
IrishMac
Moderator Emeritus
Thanks for the options, guys.
Old Jun 10, 2008 | 11:35 PM
Bill Dearborn's Avatar
Bill Dearborn
If you don't already have the bra get the Z06 version which has openings for the Z's front intake screens.
Bill
Old Jun 11, 2008 | 12:06 AM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
Bill
Smart!
Old Jun 11, 2008 | 12:13 AM
IrishMac's Avatar
IrishMac
Moderator Emeritus
Bill
I purchased the bra before I got the Z06 intake screens. I guess I'll have to resort to cutting some holes in 'em.
Old Jun 11, 2008 | 09:07 AM
bucwheat's Avatar
bucwheat
TIA.
I have wondered if you can do this without the fabric stretching and becoming useless. I have had my GM bra for 8yrs. and still fits like new.
Old Jun 11, 2008 | 10:28 AM
jovette's Avatar
jovette
I've wondered the same thing............that's what has kept me from, thus far cutting into my GM Bra............Seems like just punching several small holes might not hurt, since there would still be clear vinyl remaing to hold the fabric in place and not baloon up, when doing highway speeds.
Old Jun 11, 2008 | 02:03 PM
hotwheels57's Avatar
hotwheels57
An upholstery shop should be able to add some welting material around the edges of the cut out to maintain the shape...
Old Jun 11, 2008 | 02:09 PM
Allzwell's Avatar
Allzwell
St. Jude 15 Year Donor
Cruise-In VIII Veteran
St. Jude Donor '03 thru '20
Cutting any of the GM bra won't help a Blackwing breathe better. All of the air for the Blackwing comes from underneath unless you have cut-outs in your fog light surrounds.
Old Jun 11, 2008 | 02:42 PM
jovette's Avatar
jovette
True, but then I DO have the after market fog lamp surrounds with the holes in them, so I would receive some benefit.
Old Jun 11, 2008 | 09:15 PM
Allzwell's Avatar
Allzwell
Well then cut away
Old Jun 11, 2008 | 10:30 PM
FFIN90's Avatar
FFIN90
From: ================ From Toronto ================ 9/11/01 FDNY 343 Never Forget
CI 6-7-8-9-10 Veteran
St. Jude Donor '08-'09-'10-'11-'13-'14
I cut the plastic out completely and had my upholstery guy sew a couple pieces ( yellow arrows ) on to keep it from flapping around, works great.
Old Jun 12, 2008 | 10:30 AM
jovette's Avatar
jovette
Can you explain in more detail what you (your upholstery guy) did to keep the bra from flapping in the wind following removal of the clear plastic covering the fog light surrounds?
Old Jun 12, 2008 | 07:00 PM
FFIN90's Avatar
FFIN90
He sewed 2 pieces of 1" wide webbing onto the underside of the left and right side of the bra where the plastic was cut out.
Unfortunately I cannot use the bra anymore ( without MAJOR mods to it ) as I added a front spoiler and the bra will not fit to snap on the underside of the front end of the car.
To GM bra question
