As Of Today, I Am Experiencing A Rough Idle When I Am Fully Stopped. When I Take Off The Car Hesitates Til It Gets To About 10 Mph And Then Runs Perfectly Fine, Once Again The Same Thing When I Come To A Complete Stop. Fuel Consumption Does Not Change, Car Doesnt Stall, Starts Perfectly Fine. I Am Just Wondering Step By Step What To Look At Before Taking An Appointment At The Dealer.
I Am Sure This Has Been Covered In The Past But I Am Looking Through Some Previous Posts And None Talk About The Hesitation On Take Off.
I Appreciate All Your Help And Advice, Ideas, Etc...
From: The line waiting to see Santa Claus stretched all the way back to Terre Haute, and I was at the end, Indiana
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
If your battery has gone dead or been disconnected recently, the C5 will sometimes "forget" it's idle pattern, and it has to "re-learn" it. There is a procedure for this, but I can't recall what it is. I know it's not real common. If I can find it, I'll post it.
Anyone else know this procedure?
Thanks,,,, I'll try that tomorrow,,, I had the battery disconnected for the 6 months of winter, but ran perfect the first month I re used the car, but didnt do this procedure....
Problem Solved,,,, one of the drivers side Spark Plug wire partially popped out, Thanks everyone for all your help.. I dont have the answer to why I didnt check that in the first place...lol After the whole re-learning procedure with the rough idle, I hope don't need an engine mount...
