Spak Plugs GAP
Old Jun 12, 2008 | 01:09 PM
2kbluevette's Avatar
2kbluevette
Default Spak Plugs GAP
well I have my AC Delco iridium Spark Plugs and Autolite new cables for my 2000K
What's the gap I should use for a total stock one and any recommendations to do the change??
Thank you
Old Jun 12, 2008 | 01:19 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Pre gapped at 040 I believe, great plugs! no need to gap unless you want to check the 040
Old Jun 12, 2008 | 02:13 PM
10U 99's Avatar
10U 99
St. Jude Donor '08-'09
always double check the gap
Old Jun 12, 2008 | 02:49 PM
csexton's Avatar
csexton
Chuck
Old Jun 12, 2008 | 07:42 PM
itzza427's Avatar
itzza427
2000 FRC here--Parts store book is ".040,no variation".I used it and it runs GREAT!! Most of mine needed a little tweak,,Make sure you adjust the ground strap from the side...DO NOT force anything between the center electrode and the ground you will damage the plug!!
Old Jun 12, 2008 | 08:39 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
I just looked in the manual and it says 0.060. I got NGK iridiums and they were at 0.060 and have been using them for a couple of years now, no problems.
Old Jun 13, 2008 | 12:11 AM
itzza427's Avatar
itzza427
They used different gaps on some years,,2000 is .040 in Delco Iridiums,This came up when I had a thread about the 100,000 mile myth. someone posted the same thing with a link to NGKs (I think it was NGK) list some had .060 but 2000 and most others were .040 .I guess the general experimented a couple of years.
Old Jun 13, 2008 | 12:55 AM
2KFRC5's Avatar
2KFRC5
The manufacturer of the plugs determines what the gap should be. Not GM, Ford, or whoever. The .060 gap was for the AC platinum plugs. The AC iridiums are .040. NGK, Autolite, etc, set the gap on their plug design.
I think.
Old Oct 19, 2008 | 02:12 PM
BoiseVette's Avatar
BoiseVette
This seems to make the most sense. Can anyone confirm this for stock applications?
Thanks!
I think.
Old Oct 19, 2008 | 10:30 PM
87SAM's Avatar
87SAM
From the manual:
Document ID# 1396703
2000 Chevrolet/Geo Corvette
Information on New Spark Plugs and Gapping #03-06-04-060 - (Oct 24, 2003)
2004 Buick Ranier
2002-2004 Cadillac Escalade, Escalade EXT
2003-2004 Cadillac Escalade ESV
2004 Cadillac CTS-V
1997-2004 Chevrolet Corvette
1998-2002 Chevrolet Camaro
1999-2004 Chevrolet Silverado
2000-2004 Chevrolet Suburban, Tahoe
2002-2004 Chevrolet Avalanche
2003-2004 Chevrolet Express, TrailBlazer
1999-2004 GMC Sierra
2000-2004 GMC Yukon, Yukon XL
2001-2004 GMC Yukon Denali, Yukon XL Denali
2002-2004 GMC Sierra Denali
2003-2004 GMC Envoy XL
1998-2002 Pontiac Firebird
2004 Pontiac GTO
2003-2004 Hummer H2
with 4.8L, 5.3L, 5.7L or 6.0L V-8 Engine (VINs V, P, T, Z, G, S, N, U -- RPOs LR4, LM4, LM7, L59, LS1, LS6, LQ9, LQ4)
A new spark plug has been released for use in the above vehicles. The new spark plug has an Iridium tip instead of the current Platinum tip. Due to the different tip design, the gap of the spark plug has also changed. The new spark plug, P/N 12571164 with AC Delco P/N 41-985, is gapped to 1.01mm (0.040 inches) when the spark plug is made. The spark plug gap is set during manufacturing and should not be changed or damage to the spark plug may result. Any new spark plug found to not be properly gapped should not be used.
Old Oct 20, 2008 | 12:20 PM
BoiseVette's Avatar
BoiseVette
The Delco gap is well documented. Its interesting how many engines this this covers.
Originally Posted by 87SAM
From the manual:
2004 Buick Ranier
2004 Cadillac CTS-V
2004 Pontiac GTO
2003-2004 Hummer H2
Old Oct 20, 2008 | 12:21 PM
BoiseVette's Avatar
BoiseVette
Thanks!
To Spak Plugs GAP
