I just had my windshield replaced. Although I tried to tell them what the windshield said on the etched tag, they only wanted my VIN. they replaced my windshield with "an original windshield from GM for my specific VIN" according to the local Chevy dealer. The local Chevy dealer said that the original windshield, which has the part number "08008" , and contains the second line which reads "Sunshade HUD 4.8mm", has been superceded twice, and that the current replacement windshield...which is the ONLY replacement windshield authorized by GM for the Z06 Corvette, does NOT contain the 4.8mm in the windshield code, and the correct part number is currently "09046".
My questions are:
1) Is this "09046" windshield the thin 4.8mm thickness?
2) Is there a correct (thin) 4.8mm windshield availabel?
3) Is the original 08008, 4.8mm windshield still available?
Thank god all of you knowledgable forum members are still available
Whe I needed one and got tired of the local guys run around(not available, they use this now, etc...) I got in touch with Corvette Bob, at Fitchner chevrolet(forum sponser). He'll know.
Here are the numbers that I have for the Z06 windshield (with HUD) ...
If you are ordering it through an autoglass shop it is part DW 1514
If you are ordering from a dealer the GM part is 10315114 and GM list price is $879.90
See below for a picture of what the lower right corner markings are .... The 43R-008008 (or any other 43R numbers) are not a part number .... it is the number of a "safety certificate" issued to show compliance with European standards. The DOT-376 shows the windshield meets US standards.
The correct Z06 windshield will show the line "SHADED HUD 4.8MM"
Though the gmpartsdirect site has the part "flagged" because they don't ship glass components. Call any autoglass shop in your area and give them the number I gave you in post #5 above ( DW 1514 ) and they can order it under that number if your dealer is claiming the GM number is incorrect.
Info I found..
Ok
The DW1430 windshield...listed as the replacement for the coupe - 300-400 bu cks list
and the DW1514 the designated Z06 windshield 1300 bucks list
They both show the same bug information EXACTLY!
( I browed this photo cuz the two I took didnt come out well)
