My sons girlfriend complains about windnoise on the passenger side of the z06 at high speeds, is this a common problem, normal noise in this series? I didn't have the same issue on the last c-5 but I didn't really drive it at these speeds. thanks for any input
Mine drove me nuts...Car had sat up for a while and the gaskets had curled up......Had dealer change gaskets....Much, much better now....Silicone on the gaskets helps...The glass can also be adjusted into the gaskets...Good Luck
Reason: added stuff
There is a tip in adjustment that will help cure most of the noise. A search should reveal some information on it. I did mine myself, not very difficult to do. As I recall one adjustment is on the bottom of the door and the other is behind the door reflector. Loosen one and turning out the other will bring the window tighter against the seals.
