[Z06] Need helping checking ring integrity..
Old Jun 16, 2008 | 12:44 AM
427CPE's Avatar
427CPE
Default Need helping checking ring integrity..
After noticing my car was way down on power, I decide to check it over. One thing leads to the next, now I have the driver's head off.
Seems cylinder 7 had a compression around 60 and the rest on the same bank 210-220. Basically, it was running on 7 cylinders.
After looking things over, looks like nothing is wrong though the cylinder in question was filthy. Is there a way I can check the rings without yanking the engine? I suspect they have given up their last hp. Car has 62k original miles.
http://home.comcast.net/~booth.p/h1.jpg
http://home.comcast.net/~booth.p/h2.jpg
http://home.comcast.net/~booth.p/h3.jpg
http://home.comcast.net/~booth.p/h4.jpg
What are the latest greatest strokers out there? LS3 based?
Looks like that LS3 416 at SPDC might find a home under my heads, intake and cam. Just hope my top end will work on that block.
Old Jun 16, 2008 | 01:30 AM
bullitt4110's Avatar
bullitt4110
When my number 7 went the piston had a bunch of hairline cracks between the rings and was also about 60-70 on the compression check. No extrnal signs in the engine like yours until I pulled the piston.
Old Jun 16, 2008 | 01:53 AM
427CPE's Avatar
427CPE
Not a mark on the cylinder wall. I bet it did the same thing as yours.
Old Jun 16, 2008 | 02:38 PM
Kappa's Avatar
Kappa
What top end are you planning on using for the 416?
Old Jun 16, 2008 | 03:43 PM
Z06_BluByU's Avatar
Z06_BluByU
did that happen with a stock motor?!?!
Old Jun 16, 2008 | 10:46 PM
427CPE's Avatar
427CPE
Personally I think an LS7 top end would work really well. I would probably have comp grind an XER at 234/242-112+0 cam.
I have not decided what to do, but a 346 or 383 and cam are not out of the question w/my current heads/intake which I like alot.
Right now, still in research mode...
To Need helping checking ring integrity..
