Chrome plated plastics?
Old Jun 16, 2008 | 03:13 AM
dieseldave56's Avatar
dieseldave56
Default Chrome plated plastics?
Anyone have first hand experience on the new spray on chrome plating plastic? I have had parts done with the older vacuum transfer method. That method is somewhat costly ( usually a $250 minimum) and the part has to be able to reach 165 degrees. But its triple plated and very hard and durable.
So does anyone have a company or personal experience with the spray on plating? I know that it is silver metal sprayed between two paint coatings. But that's about all I know.
I want to black chrome plate my fuel rail covers and then add the '57 fuelie script[IMG][/IMG]
[IMG][/IMG]
Old Jun 16, 2008 | 08:03 AM
J S Machine's Avatar
J S Machine
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17
St. Jude Knife Maker
Don't know how to help you with that but your idea is great. That is going to look cool!
Old Jun 16, 2008 | 06:27 PM
dieseldave56
Default hardly a better teacher than experience........
Thanks JS.
I'll post around a bit for an answer , 'cause someone knows and I know you're out there!! I guess the real question boils down to durability. Like I stated I've had dealings with the vacuum technology but the spray is new tech. The result looks decent and the price is half but durability in the engine compartment is my question.
Old Jun 16, 2008 | 06:45 PM
bencini231's Avatar
bencini231
Try this one here it's called Pauls Chrome. He's very well known by the antique car guys. You can contact them at 1-800-245-8679. Hope this helps.
Old Jun 16, 2008 | 06:57 PM
dieseldave56
Default Appreciate the reference.
bencini231 I appreciate the reference . Do you have first hand knowledge of this newer plastic chrome proccess?
Old Jun 16, 2008 | 11:10 PM
bencini231's Avatar
bencini231
As far as knowledge on how the process is done, i don't know that much about it. I have saw pieces with this process and it looks the same as if the parts were metal pieces chrome plated.
Old Jun 18, 2008 | 03:14 AM
dieseldave56
Default cost to chrome plastic has inflated.........
I used these folks some time back for smalled pieces and just got their cost quote for the fuel rail covers.http://www.4chrome.com/PlasticChrome.htm
Thses folks use a process that uses copper , nickle and chrome to plate the plastic. Realize that the parts will feel and look like metal. But at $4.50 per sq inch that puts the cost of plating both my fuel rail covers at $1454. Ooouch. So looking for and alternative process still.
Old Jun 18, 2008 | 04:26 AM
slverc5's Avatar
slverc5
Try this shop. A friend of mine used them before. Price is pretty reasonable. Although I was told that there turnaround time is about 4 weeks.http://www.specialtychromedplastics.com/ordering.htm
Old Jun 18, 2008 | 07:21 AM
nj02vette's Avatar
nj02vette
From: Marlton. Increasing performance one speeding ticket at a time! NJ
There are several methods to plate plastic.
Metalic paint:
You can paint yourself, polish, then send out for chrome.
Vaccuum deposition:
Need qty and usually min setup charge.
Flame spray:
Never used but hear good things.
Plating:
I use a company called Cybershield in TX to plate plastic. They are great. They'll plate directly onto plastic. They are an industrial house, so not sure if they'd take small orders, but they may point you in the right direction.
Hope this helps
Old Jun 18, 2008 | 11:57 PM
dieseldave56
Default Terriffic guys , thanks...............
I sent off for quotes from both companies. I will also want to chrome plate the intake manifold if this works out on the fuel rail covers. Thanks again!!
Old Jun 19, 2008 | 12:11 AM
zonsolo's Avatar
zonsolo
Wish you luck on this. There has to be a cheaper way to get the look you want, I'm sure model car companies (Revel, etc.) don't pay those dollars to get the bumper/chrome section for a plastic model done, or the model kits would have to cost a fortune.
There is a company here in mansfield, ohio that chromes plastics for GM/Ford, etc, name is Jay Plastics. But I highly doubt they would be interested in a one-off project.
Old Jun 20, 2008 | 02:52 AM
dieseldave56
Default All plating is not equal..............
Well it appears that , as with metal coating not all plating is equal. As I have yet another company that uses the same vacuum technology give me a quote of $125 to $150 ( if more hand sanding becomes neccessary) . That's 5 times less than the first quote.
I expect to have other quotes coming in but I did send this companyhttp://www.specialtychromedplastics.com/ a copy of the first company's quote and asked why the hughe difference in prices? Am I missing something. Because if this looks like I think , I might consider doing the intake manifold as well.
To Chrome plated plastics?
