[Z06] Max H/c Power Gain???
Old Jun 18, 2008 | 10:20 AM
Max@Cartek's Avatar
Max@Cartek
The most power is one thing, but the fastest/quickest is another. You can get peaky numbers that will look nice on paper, but a broader power band with lower peak numbers will actually go faster. My point is... what are the intended uses of the car? How fast are you looking to go?
Building the car to perform will make you happier than getting a nice dyno sheet.
Old Jun 18, 2008 | 02:21 PM
carlsbad's Avatar
carlsbad
I want it to be a aggressive daily driver, i want to get a round 550 BHP
Old Jun 18, 2008 | 02:31 PM
jpandes's Avatar
jpandes
Nice numbers guys!
My next mod(s) will be an upgraded clutch, as the stocker is already slipping on on a cam only Z06 and then some nice heads.
Old Jun 18, 2008 | 02:33 PM
carlsbad's Avatar
carlsbad
More Numbers Please
Old Jun 22, 2008 | 08:51 PM
Max@Cartek's Avatar
Max@Cartek
Then 550 BHP is very easy to get.
Give me a call if you want to discuss the options and expected results.
Max
908.317.4496
Old Jun 23, 2008 | 03:44 AM
RonVette2's Avatar
RonVette2
Boost it.
Old Jun 23, 2008 | 10:10 AM
TBSHOP's Avatar
TBSHOP
More Numbers Please
Mine did 463RWHP with ADR3 cam, GFI 243 heads and AR headers w/cats. Hope this helps.
Old Jun 23, 2008 | 11:27 AM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
I made 448rwhp, 432rwtq with a LG's G5X1-E cam, AFR205's (milled to 59cc), LG Pro Long Tubes, Vararam. Torque on this car is fun to say the least
Mod list on my web page (see my signature below).
I was told that with a Fast 90/90 intake I could get another 20rwhp. ~470rwhp would not be too shaby for such a drivable cam.
Toque
Old Jun 23, 2008 | 03:07 PM
Diamond's Avatar
Diamond
Cruise-In II Veteran
Cruise-In III Veteran
431 rwhp with 233/236 cam and Texas Speed 5.3 heads. Vararam, headers, stock Ti exhaust.
Old Jun 23, 2008 | 04:47 PM
QUIKSILVERZ's Avatar
QUIKSILVERZ
Toque
this is the same setup i plan on doing with my 02 Z . i talked to anthony/lgm about what i wanted out of my z. it is a street car first then a open track car.
Old Jun 23, 2008 | 04:54 PM
Toque's Avatar
Toque
Anthony is a good guy.... Your in good hands for sure ! Its hard to believe such a drivable cam can make the TQ and HP that it does.
Toque
Old Jun 23, 2008 | 05:05 PM
SRVVR's Avatar
SRVVR
I have a well-built and tuned car that I can drive VERY easily on the street. Have the car built for what you intend it to be used for and enjoy it from there. I only use the dyno as a means of benchmarking to see positive/negative increases for my car and my only, I do not use it for comparison to other vehicles.
By the way, mod list is as follows and I'm estimating that it'll be 420-430 rwhp:
  • CAI (will be replaced with a single filter unit rather than dual)
  • Ported TB and Intake (LS6)
  • Mild Cam (unsure of specs)
  • Longtubes
  • X-pipe
  • Cat-back
Installed and tuned by Quality Motorsports and I'm very pleased. I just got it back about 2 weeks ago...
Old Jun 23, 2008 | 09:35 PM
  #33
carlsbad's Avatar
carlsbad
great!
