[Z06] Kooks Questions please
I have a 02 Z06
1. How easy was the install?
2. Do they bolt right up, or require any welding?
3. Advantage- with or without cats? Im in Alabama (not required)
4. Regular driving and performance driving opinions.
Thanks for any and all input.
I had a buddy tell me I would like the Kooks header better than the LG streets, he did not say why.
Mark
2. They bolt right up and shouldn't require any welding.
3. I don't think you'd lose any appreciable power by running the high flow cats. Without the cats, even with an otherwise stock car, you're like to get some fuel smell at idle.
4. They're a hoot. I say go for it!
No welding required I'm running no cats but couldn't tell you the advantages of that unless I had a Dyno and could compare with and without cats. One thing I can tell you, without cats, you do get a little bit of fume smell inside the car, especially on stops (ie; lights or stop signs).
As far as performance, I didn't notice any performance gains at all until I had the car tuned. As far as the sound? I love it
, I'm still on stock TI, but under acceleration, it's sounds amazing (nasty roar at WOT)
All in all, it only took about 2 hrs for a complete header/xpipe install with the said tools and mentioned procedure.
FWIW I went without cats. The reason I did this is because its a lot cheaper and there is more power to be made, even if it is only a few WHP.
A car can actually pass an emissions test without cats, contrary to what all the tree huggers on here will tell you. And if you don't drive the car 100,000 miles a year, it will also have an insignificant impact on the environment.
So yeah my vote is Kooks w/o cats.
Also and I really cannot stress this enough as someone with B&B Bullets, but the biggest difference was going from about loudness 10 to about 7. Having the deafening exhaust was fun for a while but it got old really fast. Not because the noise wasn't beautiful, but because you couldn't get on it at all without causing drivers around you to react, 99% of the time unfavorably, and attracting the attention of the police.
After I put the cats on I could actually drive the car with more enthusiasm on the street since it wasn't so GD loud all the time. Setting off car alarms and getting the little letters in the mail from the CHP saying someone complained about your car is only fun if your still a teenager, as an adult it just got old. So considering they have no noticeable performance downside I would get cats, unless you want to run a more restrictive, heavier muffler setup that would be quieter than the Bullets thereby negating the sound issue. But really a modern state of the art cat doesn't affect your car unless you are going for 1000hp or something. The smell of no cats gave me a headache after a lot of stop and go driving too. I just had to put them in.
