Paint spot from bird dropping. i need help ?
Old Jun 17, 2008 | 12:05 PM
cfp Z06's Avatar
cfp Z06
Default Paint spot from bird dropping. i need help ?
Hi guy's , newbee 03 Z06 . i had a bird dropping on the hood (1/2"dia.)
it was there 24 hours. it left a stain even after washing. i tried a clay bar
it's still there. this car has a beautiful finish on ,it garaged ,11K miles, it's babied. How do i remove this spot? it looks like it eat through the clear coat. the car color is torch red.
HELP?
thanks
Old Jun 17, 2008 | 12:08 PM
Daddyrama31's Avatar
Daddyrama31
If it ate threw the clearcoat, you can't fix. You will need to take it to a paint shop and have it re-cleared.
Old Jun 17, 2008 | 12:11 PM
VaTechHokie's Avatar
VaTechHokie
try using a paint cleaner or compound on the spot, it should come out.
ZPC usually works to get the bird stains off of mine.
Old Jun 17, 2008 | 12:12 PM
MagRedConv's Avatar
MagRedConv
Try a search in the Car Care section.
Old Jun 17, 2008 | 12:38 PM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
The clear coat is much thicker than your red base coat.The bird dropping probably only etched the top surface of your clear finish.
Rub out the area with WHITE polishing compound on a dampened piece of terry cloth.Then apply your favorite polish or wax over the area.
Old Jun 17, 2008 | 12:40 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
with the above replies...
I'd try claybar (the most abrasive grade first)...
Old Jun 17, 2008 | 12:54 PM
cfp Z06's Avatar
cfp Z06
do you have a link for White polishing comp & or different grades of clay bar?
thanks
Old Jun 17, 2008 | 12:58 PM
MyVetteDream
thanks
AutoZone sells Mother's claybar/spray lub for about $20.
Old Jun 17, 2008 | 12:59 PM
ScottGJones's Avatar
ScottGJones
Go over to Autopia.org, they will know how to properly correct your spot. You can try a clay bar, but it won't be agressive enough.
http://www.autopia.org/forum/guide-d...nt-clinic.html
Hope that helps. Hang out there and drool over the cars in Click and Brag, then you'll become an OCD (Obsessive Compulsive Detailer) too.
Old Jun 17, 2008 | 01:00 PM
EVIL_C5's Avatar
EVIL_C5
Uber Waxer
Cruise-In 8-9-10-11 Veteran
CI 9, 10 & 11 Car Show Winner
St. Jude Donor '08-'10
clay wont remove that, you will need to have it removed by someone that can use a rotary to properly level the paint back out.
Old Jun 17, 2008 | 01:02 PM
GrayC5's Avatar
GrayC5
Yep, this has been discussed any number of times in the Car Care Discussion section of the Forum. Too, several very knowledgeable people and few professional detailers hang out in that section and they may be the ones that can best help you with this topic.
Good luck with the fix.
Old Jun 17, 2008 | 01:03 PM
BonestockZ06's Avatar
BonestockZ06
thanks
Forget the claybar, that will remove any bird droppings left on the paint, but will not remove the stain. Go straight to Polishing compound. You can pick it up at any local pepboys, autozone, etc. Hit it with a damp MF cloth and follow it with what ever wax you use. You may have to repeat the polish process till it's completely out, but it's a sure fix.
Should take no more than 10 minutes.
Old Jun 17, 2008 | 01:12 PM
cfp Z06's Avatar
cfp Z06
thanks to all of you guys.... i'm new to all of this ...it's GREAT...
My wife thinks i'm nuts with all the fussing over this machine....
but she comes out of the garage saying " that car is so cool i love looking at it"
thanks
Old Jun 17, 2008 | 01:15 PM
ROADAPPLE's Avatar
ROADAPPLE
Old Jun 17, 2008 | 01:40 PM
EVIL_C5's Avatar
EVIL_C5
Uber Waxer
sorry to break it to you, but c5 clearcoar is very hard, its very doubtful that you will remove any etching from the finish by hand unless you work on that same spot for a very very long time.
a professional with a rotary could probably fix that 1 spot in less than an hour.
Old Jun 17, 2008 | 01:44 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Mine is gone now
It took a year and a half
Peace
Chip
__________________
..................Click for
Old Jun 17, 2008 | 01:55 PM
EVIL_C5's Avatar
EVIL_C5
Uber Waxer
Originally Posted by Willfulone
Mine is gone now
Peace
Chip
next time call me....
To Paint spot from bird dropping. i need help ?
Old Jun 17, 2008 | 05:33 PM
rcs128's Avatar
rcs128
This man know's his stuff.
Old Jun 17, 2008 | 05:48 PM
PETE O.'s Avatar
PETE O.
Damned birds! There oughta be a law
I've had the same problem with anything that sits outside for more than ten minutes. My wifey feeds the damned things and they show their appreciation by leaving deposits on my rigs
I use Meguiar's Cleaner Wax and a bunch of elbow grease. It gits-r-done
Old Jun 17, 2008 | 06:33 PM
Redneck Slim's Avatar
Redneck Slim
Active Streak: 90 Days
I have always removed these stains with my normal wax.As long as the wax has some abrasive in it,repeated polishing will gradually get the stain out of the clearcoat.
