[Z06] How many flats
#1 How many flats have you had on your Z ??
#2 Do you know how many miles on the tires before you had a flat ??
#3 Or miles between flats ??
#4 What caused it ??
#5 What did you do?? A: Fix it on the road.. B: Call AAA.. C: Have it towed ?? D: Call a friend wth I need ??
#6 How far away from home ??
#7 If no flats how many miles have you drove ??
As this was a C4 I just slapped on the little space saver spare and drove home. The point of this story is that in the intervening week I drove a car with max neg camber very very hard and over 100mph many times before it finally failed. The handling felt unsettled but not as horrible as you might think. Point is, getting a modern tire to fail is really a lot of work, even with nails in them and such you can usually drive slowly to a place to get it repaired until you can buy a new set of tires for that end of the car.
I have the tire repair kit for my C5Z but to be honest I am just going to buy can of that fix a flat stuff that is non gooey/messy. I just need to research and find out which brand it was again. I get a little leak I will hit it with that and drive it home and call Tire Rack. Just my .02.
btw, the '89 and later space savers from the C4's are aluminum, very small and fit over big brakes. If you were really a worrier you could just put one in the spot in the trunk of the Z and use it if you got a flat. Just keep it in a plastic bag for looks reasons and also to put the tire that went flat in since it will be on your front seat or floor since I dont think they will fit through the small C5Z trunk opening. I use the race heim jointed end camber bars on the C4 now.
In 30k with the C5, I did get a screw in one rear and it didn't leak for months. As long as it wasn't leaking I wasn't going to pull it out to see if it went all the way in. It just started to leak when I got to the tire store to get new front tires. I seem to have a small nail in the other rear tire. Its not leaking and I am not pulling it out till I have a reason (track day or leak).
Zero
I carry an inflater and a plug kit and or a GTO spare on road trips.
It worries me more on the coupe, as I have 19" rims with fairly odd sized tires on it, but I guess you gotta take your calculated risks.
best regards -
mqqn
