the trim on my '02 finally cracked...I have both replacement pieces...can someone walk me through the job..or should I pay the body shop $100.00 to do it?
Search feature on this forum. Type in replace moulding or something along those lines and you will get some info to read.
I've also been trying to get this done, its my understanding that its heald together with a couple of screws and adhesive....I haven't done mines yet but hope to do it soon.
Been working on this for awhile doing my conversion from a coupe to a FRC.
Plastic molding is glued on with weather adhesive to seal to roof panel and then screwed in. Rubber outside weather stripe is then pushed in to the channel.
It's PIA job and will require alot of time to remove, clean and prep the old spots where the channel was glued on.
