Traction Control/Active handling
To answer, yes, that's what it does. Applies the correct brake and shuts down engine rpm's to correct for incorrect heading in relation to the steering wheel. I thought all 2000's had it though. look on your rpo code list for JL4, if it's there you have it. And of course you'd have the round button on the console, so you'd probably notice. If you also have competitive driving mode, you can hold that button down for about 10 seconds and "competitive driving" will appear on the DIC. That will allow the wheels to spin, but still activate control if you start to slide.
Active Handling is separate from traction control. It uses brake applications to control the yaw rate of the car. Say you are going into a turn and as you turn the steering wheel the front wheels start to push so you increase steering angle to compensate. AH takes into account the steering angle (steering sensor), the wheel speeds at each wheel (wheel speed sensors), the yaw rate (yaw rate sensor in the dash under the radio), lateral Gs (from lateral G sensor under passenger seat) and determines if the yaw rate (how quickly the car is changing direction) will achieve what the driver is intending. If it isn't changing enough the system will apply the brake on the inside rear wheel to cause the car to yaw more quickly in the direction the driver intends to go. Conversely, if the rear of the car is swinging out too fast the system applies the brake at the outside front wheel to slow the swinging of the rear so the car goes in the direction the driver is pointing it. In other situations it may apply both rear brakes to create the correct yaw condition in high speed corners. It does all this in conjunction with traction control unless you are in competitive handling mode and then traction control is turned off and the operating band of AH is opened up so the driver can throw the car around a little more before the system activates. When you are braking and cornering at the same time the system works in conjunction with the ABS system to control yaw rate.
GM is well ahead of its competitors in this area as the Corvette system is the most sophisticated system on the market and works a lot better than any other. It has been 7 years since the latest version of the C5 system came on the market and the competitors still haven't matched it even though they use some of the same components.
Bill
Bill
Unless you are tracking the car or acting as an idiot on the streets, it's hard to tell the difference. You should maintain control of your car as if it didn't have active handling in the first place while on a city street or highway. Granted, there are those rare occasions where maybe the street is wet or a corner a bit tighter than you thought or prepared for, or run off the highway with two wheels in the dirt then try to get back on again at speed, then, yeah...it's nice to have.
Everyday driving around town and I can't say I've ever been put in a position where if I had AH, it would have come on.
It is for the most simplistic analogy, a device that assists in correcting severe oversteer or understeer. That's about a simple, even though it is far more complex than that.
Bill
tires are turning but the front tires are not during the burnout.
The line lock itself does not cause that code. You should be able to reset it.
The only other thing is that it may be a coincidence that the code came on for some other reason when you were at the track.
Max
908.317.4496
