Gauge Bezel fell off
Old Jun 18, 2008 | 12:39 PM
BUGZ's Avatar
BUGZ
Default Gauge Bezel fell off
Anyone know the source for the original adhesive that came with the Bezels? I read that some have had an issue with using super-glue because it has a tendency to out-gas and fog up the clear gauge cover. So I thought I would try to use with the original stuff. The outside temperature here got up to 109 degrees yesterday (much hotter inside the car) and one bezel fell off.
Also; since I will have the dash and console dismantled to re-apply the bezel, are there some other enhancements or mods you would recommend?
Oh...just thought of one....MGW shifter
Thanks in advance for your help.
BUGZ
Old Jun 18, 2008 | 12:47 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Oh...just thought of one....MSG shifter
BUGZ
Not sure what they use on the Bezels, I had a chrome insert fall of and I went to Lowes and got some very thin dbl backed 3M tape and it worked great, The trick is to use denatured alcohol to clean the surfaces really good.
jmo
Bill
Old Jun 18, 2008 | 12:50 PM
GRUNIE's Avatar
GRUNIE
I would like to do this mod but have seen so many posts about the rings falling off, I just forgot about it
Old Jun 18, 2008 | 01:12 PM
minitech's Avatar
minitech
Could do an LED mod to the DIC buttons. Just going white makes them so much brighter. Consider blue or red. Lot of info on how to with search here.
Old Jun 18, 2008 | 02:10 PM
BUGZ's Avatar
BUGZ
ttt
Old Jun 18, 2008 | 02:22 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Super Glue is used to hold on the rings.
Old Jun 18, 2008 | 02:25 PM
tellefan's Avatar
tellefan
Go to a hobby shop and buy medium viscosity CA glue. CA glue is a form of super glue but works much better. I use it for all kinds of stuff, I never waste my time and money on super glue. Leave the lens off overnight so it can off gas. David
Old Jun 18, 2008 | 02:35 PM
DavzC5's Avatar
DavzC5
From: Houston, TX www.djmotorsportaccessories.com Specializing in C5 & C6 Accessories. DJ Motorsport Accessories.
St. Jude Donor '08-'09
Check out this thread..guy used Black RTV and was very please over superglues that cause fumes or harden and fall off.
http://forums.corvetteforum.com/show....php?t=2050345
Old Jun 18, 2008 | 02:46 PM
wildbadbill's Avatar
wildbadbill
did mine a week ago.I used super glue for PLASTICS instead of supplied double stick tape.The reason-even that it's pretty thin the tape will set the rings closer inside the gauge and block some of the fine numericals.IMHO
Old Jun 18, 2008 | 03:33 PM
BUGZ's Avatar
BUGZ
Thanks for the responses....Got three contenders to consider:
Double Back Sticky tape (3M?) (the heat may let the bezel sag over time),
Medium Viscosity CA Glue (still has out-gassing issue),
Black RTV (high temp Black RTV may be the way to go) I think I still may have a tube I used to seal Jeep differential cover.
I'll let you know what I finally go with.
Old Jun 18, 2008 | 04:12 PM
ljthe2nd's Avatar
ljthe2nd
People have had problems with them falling off using regular superglue. If you use the superglue gel this seem to solve the problem. Just leave the lens off for 24 to 48 hours and you wont have any gassing problems. If you use the hobby shop type superglues you will still have the same problem unless you use the thicker glue the problem is when you use the thin superglues if you put too much on it will run out or drip and cause a mess so you just put on a little with the superglue gel you can put more on and get a more even coat.
Old Jun 18, 2008 | 04:22 PM
minitech's Avatar
minitech
The stuff they sent with mine looked like CA gel.
Old Jun 18, 2008 | 04:32 PM
SUPERCRUZ's Avatar
SUPERCRUZ
I used the DURO brand super glue gel. My bezels have been on for close to 2 years and no issues. I threw the liquid stuff they sent with my kit away. Good luck with it.
Old Jun 18, 2008 | 04:55 PM
BUGZ's Avatar
BUGZ
Edit....four to consider:
Superglue "Gel". (sounds promising)
I like the sound of the Gel stuff. The key is to let it out-gas / cure for 24-48 hrs
Old Jun 18, 2008 | 06:01 PM
Mike Mercury's Avatar
Mike Mercury
the problem with using superglue of any viscosity... isn't the glue; it's the aluminum rings that expand and contract with temperature changes over the years.
All superglue dries hard and is not flexible. A few seasons of the aluminum bezels expanding and contracting will eventually break them free of the surface they were originally superglued to.
The suggestion to use a flexible adhesive (RTV or SUPER RC Z 56) in an excellent one.
Old Jun 19, 2008 | 10:57 AM
BUGZ's Avatar
BUGZ
Mike,
Is the SUPER RC Z 56 available at a typical auto parts store or is more of a Hobby or Hardware item?
Thanks for your input
BUGZ
Old Jun 19, 2008 | 12:37 PM
ljthe2nd's Avatar
ljthe2nd
RTV is just silicone, If you want to go this way just go to home depot or lowes and get the cheapest silicone calking or bath tub sealer. If you want clear or black you'll have to go to the auto parts.
To Gauge Bezel fell off
Old Jun 19, 2008 | 03:10 PM
Mike Mercury
Mike,
BUGZ
It's more a craft type glue; sold at hobby shops. But RTV is available everywhere - and it's thicker (easier to manage) than the RC 56.
Old Jun 19, 2008 | 03:22 PM
XtremeVette's Avatar
XtremeVette
Original Founding Member!
Cruise-In 1, 3, 9. 10 & 11 Veteran
Default I used the gel.....
I used the Gel....and never again...It ruined my bezels and my gauge cluster. I left the clear plastic off and let the rings sit overnight. When I got up in the morning...what a surprise....White haze from the glue all over the rings and my cluster! Completely ruined. I had to get replacement rings and had to repaint my cluster. So word of warning....if its humid out, don't do the superglue at all. I would say use the High heat black RTV.
Stay away from the Gel....nothing but headaches, both now and later.
Old Jun 20, 2008 | 12:14 AM
jbridgett's Avatar
jbridgett
After reading about all who have had bezels fall off using superglue, I used a thin coat of 5 minute epoxy put on the back side of the bezels with a brush. Put the cluster back together 1/2 hour after I mounted the last bezel. No gassing and no falling off problems after 3 months.
