Window Valet Group Purchase!!!
Vernon,
Ca, Us 06/26/2008 3:00 P.m. Adverse Weather Conditions
06/26/2008 2:00 P.m. Mechanical Failure On Railroad Flatcar
But it's ok since
ONTARIO,
CA, US 06/30/2008 4:34 A.M. OUT FOR DELIVERY
One thing I noticed though is that when raising the windows (after pressing the "lock button" three times) you have to press the lock button on the key fob again when they're up otherwise they go back down again. They don't stay up.
Configuration Menu Structure
To enter Configuration Menu Mode: Hold the DIC 'reset' while pressing
the door panel 'unlock.' Do not do this while driving or while the key is
ON. Press ‘reset’ to exit and abort any incomplete changes.
1 - Panic! mode
2 - Display high speed
1 - clear high speed from memory
*2 - select US-style speedometer, 0-200 MPH
3 – select export-style speedometer, 0-300 km/h
3 - Activate accessory power
4 - Enter configuration menu
1 - configure windows
*1 - disable
2 - enable and calibrate windows [requires PIN]
3 - window up strength, normal [requires PIN]
4 - window up strength, strong [requires PIN]
2 - configure door locks
*1 - disable
2 - active on hand brake
3 - active on transmission in PARK
4 - active for both 2 and 3
3 - configure accessory power
1 - disable control
2 - activate power on exit
*3 - activate power on triple unlock via FOB
5 - adjust accessory power timeout
1 - 30 seconds
2 - 5 minutes
*3 - 15 minutes
4 - factory defaults (factory defaults are marked with *'s)
1 – restore to factory defaults
You are correct, you will only be billed the 135.00
Thanks for the order,
Jim
$135 shipped....
Order here....Minimum order quantity met, immediate shipment, great price....
You can place your order at the below link if you want in...
Corvette Window Valet
Jim
