[Z06] O2 codes after Installing Headers
Old Jun 23, 2008 | 06:29 PM
rgforrest's Avatar
rgforrest
1st Gear
Default O2 codes after Installing Headers
I’m the original owner of a 2002 C5 Z06. I’ve installed a Vararam VR-2B ram air intake, Dynatech LT exhaust system (headers, high flow cats, x-pipe) and Borla Stinger cat-backs. I have NOT changed the factory program.
After driving several hundred miles I started to see front O2 sensor codes (P1033 & P1053). I’d clear them and they would continue to come back. There is also residue building up at the tips indicating that the car is now running rich (dark black, cakey build-up, UG! ). Because of the codes I’m not able to pass the Texas pollution inspection.
I’ve taken the car to the GM dealer who after two weeks which included replacing the front O2 sensors has been unable to resolve the reason for the O2 codes. The GM mechanic felt that I had a sever carbon build-up problem. After a lot of injector cleaner and 2, 4-hour highway runs I’m still throwing the same front O2 codes.
Any comments/help would be GREAT!!!
Old Jun 23, 2008 | 06:40 PM
Millenium Z06's Avatar
Millenium Z06
Moderator
Most people get the rears (0430 and 0420) to throw a code after header installs, I did. You may have to go and get a tune done. The obvious thought would be that they are connected wrong but since you say the dealer I assume they double checked that; could be wrong though.
Old Jun 23, 2008 | 09:09 PM
sublime1996525's Avatar
sublime1996525
I got the 0420 code after my header install. Something is probably installed wrong.
Old Jun 23, 2008 | 09:23 PM
got2hav1's Avatar
got2hav1
2019 C6 of Year Finalist (performance mods)
I got the codes too after LG pro install. First make sure you have no leaks. I had to fix leaks on both sides. Codes still appeared. Finally bought two new sensors and replaced, codes went away and haven't come back yet. But I see you have already replaced yours . Did you use GM sensors. Unfortunately this is pretty common with long tube installs. You can search the forum there is a ton of stuff on the subject.
Old Jun 23, 2008 | 11:35 PM
striper's Avatar
striper
If you call Doug at East Coast Supercharging he will explain to you what is going on. He probably can fix your computer by mail. 609-752-0321.
Old Jun 23, 2008 | 11:55 PM
Blue Blood's Avatar
Blue Blood
St. Jude Donor '08-'09-'10-'11-'12-'13, '15,'21
Had the same problem. After about a month now I've been clear.
I purchased the adapter plugs from LG and switched the rear O2's to the front. Don't know if it's because the rear sensors supposedly burn hotter and react faster (I've read this several places) or if they were new, but it's working.
You will need the tune, and I would suggest using some seafoam (search) to clean intake passages and the motor top end (change oil afterwards).
good luck.
Old Jun 24, 2008 | 12:15 AM
jclarksnakes's Avatar
jclarksnakes
You may have the connectors for the sensors crossed. It has happened before.
To O2 codes after Installing Headers
