Outside Air Temp. Sensor Problem
Old Jun 27, 2008 | 10:37 PM
keithk's Avatar
keithk
Default Outside Air Temp. Sensor Problem
Got a question...Just got my car back today from body shop. Had to have some touch up work done on front bumper. When I got in the car I noticed the outside temp read -17. (Impossible since I'm in Alabama in the middle of June). Any ideas on how to fix this problem since the air will not work until the correct outside temperature is established?
Old Jun 27, 2008 | 10:51 PM
MagRedConv's Avatar
MagRedConv
Check out this thread and also do a search on the sensor - http://forums.corvetteforum.com/show...erature+sensor
Old Jun 27, 2008 | 10:59 PM
keithk's Avatar
keithk
Default Thanks
I appreciate the help. I will check it out this weekend and hopefully have it back to the correct Alabama reading of 96 degrees before the day is out.
Old Jun 28, 2008 | 10:24 AM
c5streak's Avatar
c5streak
Sensor is part # 10248414, about $10 at the dealer. If you unplug the sensor the A/C should default to 69 deg, and allow your compressor to come on. The sensor is under the front air dam on the pass side, right below the end of the radiator. It's held in by a plastic push pin, asbout a 2 min job. After changing the sensor, you will need to drive the car a mile or so before the new sensor will "read" and start working. Manual states XXXmph for XXX minutes, I don't recall the specifics, but a mile or so will do it.
Old Jun 28, 2008 | 11:12 AM
rws.1's Avatar
rws.1
Here is a pick of what it looks like.... looking from the passenger side of the engine bay down and towards the front rail
Old Jun 28, 2008 | 11:36 AM
vetterlatethannever's Avatar
vetterlatethannever
Very easy and very cheap fix.
I procrastinated and once I did buy the part (no Corvette tax!!! about 10 bucks!!) and put it on (a few minutes, no more!!) My A/C was back working. I had a bad sensor that was reading -xx degrees and so my AC would not work. This was in the summer and I found threads about how cheap and how easy it was to fix and thought 'no way, can't be that simple'. It is, and I feel really dumb for waiting and going without my AC for that long.......
Old Jun 29, 2008 | 04:11 AM
keithk's Avatar
keithk
thank's for the help
Old Jun 29, 2008 | 02:31 PM
JC in XTC5's Avatar
JC in XTC5
Keep in mind that the sensor is a thermoresistor and as the temperature decreases the impedance increases. In other words, to report a temperature that low the sensor circuit impedance would be going way up although not an open circuit. Check the connector for corrosion as it could be affecting the contacts and giving you this problem.
Old Jun 29, 2008 | 05:12 PM
c5streak's Avatar
c5streak
If you want to check your sensor, here's the resistance reading for corresponding temps:
Temperature vs. Resistance Values
F° = Ohm
-40 = 242,700
-22 = 177,000
-4 = 97,060
14 = 55,319
32 = 32,654
50 = 19,903
68 = 12,493
86 = 8,056
104 = 5,327
122 = 3,603
140 = 2,488
*ohm readings are approximate
To Outside Air Temp. Sensor Problem
